Defi boost gauge install w/ pics
Old Oct 12, 2004 | 09:55 PM
  #31
mtsevovii's Avatar
nice write up, used the instructions, helped alot, although it took me a while to figure out the plug for the hose, since i have a jdm, its on the other side, so it was under the driver side instead of the passenger, haha. after that its went like a charm.
Old Oct 22, 2004 | 11:18 PM
  #32
crusin_lancer's Avatar
In your instructions you have it after the solenoid. Does it matter if it is before or after?
Old Dec 18, 2004 | 06:45 AM
  #33
AUSS1E's Avatar
Originally Posted by EVO8LTW
I just used these successfully with one modification. I tapped the yellow/black wire off the dimmer rather than the black wire so that the gauge would dim with the dash. Otherwise, the directions were perfect! Thanks.
I tried it this way and it worked.....but the gauge dimmed the opposite of everything else....Any ideas on why it would do that??? or how to get it right??
Old Jan 25, 2005 | 03:45 PM
  #34
GVR-4's Avatar
Sorry for resurrecting a thread that should probably be dead, but I have not found anybody discussing the issue I bring up below even after searching the archives.
Does anybody else besides myself have any issue with taping into the fuel pressure regulator line to run the boost guage? I am worried about loosing signal/pressure to the fuel pressure regulator and potentially running lean. I know all the fittings will be tight at least initially, but an accidental leak at a later date could mean big problems.
There are a few other points you can tap into, depending on your gauge (if you need boost and vacuum or just boost), two on the throttle body and a couple more on the intake manifold (brake booster, BOV, waste gate).
The autometer gauge I'm about to install is boost only, no vacuum reading. I'd prefer not to subject the gauge to vacuum. Does anybody know if one of the ports on the throttle body is upstream of the throttle plate?
I'd hate to have to pull the upper IC piping just so I could weld a nipple on there for my boost gauge.
Mark
Old Mar 21, 2005 | 07:56 AM
  #35
pgjoey's Avatar
Used this to install my Defi boost gauge this past week, awesome! Thanks!
One thing that may save some time. I opened the little storage area below the dimmer switch and reached under and popped out the side opening. You just have to feel around for the clips and unclip a couple. This way you can just unplug the light level and dimmer switch sockets vs having to pop out the harness then unhooking them.
Old Mar 21, 2005 | 08:16 PM
  #36
shadow1's Avatar
the right way to wire the lighting
I just installed my Autometer boost gauge. I wired the lighting to the dimmer switch. One wire to the black/yellow stripe wire and the other wire (doesn't matter which) to the green/white stripe. The gauge light dims perfectly with the rest of the dash. The red wire taps work great.
Old Mar 30, 2005 | 03:33 PM
  #37
EvilEvoRS's Avatar
Tap into the cigarette lighter and the gauge will actually dim along with the cluster and instruments, but I am running 3 gauges in the center and have no stereo in my RS. I'm not exactly sure how well it would work to run the electrics from the steering column down to the cigarette lighter. Just thought I would share if you wanted your gauges to dim.
Old Apr 11, 2005 | 05:53 PM
  #38
Gabriel Knight's Avatar
Fantastic write up and great pictures. Thanks!
Old Apr 19, 2005 | 06:32 PM
  #39
rExTuHfEr's Avatar
i just followed these...w00t....used it for my boost gauge.....havent installed the egt and oil yet...dont know if i will
Attached Thumbnails Defi boost gauge install w/ pics-defi.jpg
Old Apr 25, 2005 | 12:51 AM
  #40
PunoEvo1337's Avatar
i used this to install an Autometer Ultralite... i was wondering if people were having electrical problems with this ground point???
my rear driverside door will no longer electrically open
my rear windshield wiper blade wont go
my left rear light will sometimes go out
dont know whats going on
a little help...
Old Apr 26, 2005 | 09:48 PM
  #41
johny719's Avatar
maybe the grounding point isn't clean... try re-doing it
Old May 7, 2005 | 11:26 AM
  #42
Evolutionken's Avatar
hey guys...im having a little trouble here....thanks for the write up it helped alot...but now...i dont get the tapping part...how do you tap? and what do you have to tap?
Old May 8, 2005 | 03:33 PM
  #43
Thegame's Avatar
There are electical parts called "wire taps" all you do is clip one on the wire in the dimmer, add a connector to your gauge wire and plug that into the tap. It's really easy. Ask someone at your local auto parts store for some red wire taps. He'll know what you're talking about.
Old May 14, 2005 | 11:47 PM
  #44
bluebyuevo8's Avatar
just installed my defi d boost and when i give it full throttle the boost gauge jumps to like 23 lbs and then levels off at 16. does anyone elses spike this high???
Old May 17, 2005 | 06:00 PM
  #45
TheSmacker's Avatar
Ok guys, maybe you can help.
I went through the install just like it is above, but my gauge seems really sluggish (sometimes not even responding at all in 1st and 2nd gears). Also, i'm getting no vaccum, and when I let off the gas the gauge seems to only drop to about 10-11 psi and stay there until I turn the car off, then it slowly goes down to 0. Could this be a bad gauge? Anything I should be double checking? I got this thing around Christmas, and someone mentioned there might have been a bad batch of them around that time?
