HKS EIDs Install
Old Nov 6, 2004 | 08:30 PM
import_junkie's Avatar
Originally Posted by kayyoevo8
Originally Posted by co_evo
Pin number 90 in the ecu: This is the Volume Air Flow Sensor Signal to the ECU. Here is where the White and Yellow wires are used. This kind of tricky. I had to use the Japanese instructions and box in conjunction with the English instructions. If you look on the box it says in English "IN" (from the wiring harness) for the white wire and "OUT" (to the ECU) for the yellow wire. Also note that the EIDS is the last thing in chain of wiring if you have a fuel computer -(Japanese instruction).
i also installed it just like up there... and i also cant rev past 4.5 k rpm... why is that?... i got a dual horn vta bov. can someone tell me what i can do to fix this problem?... i would really appreciate it..
I'm having the same problem with the reving close to 2 k rpm and not going past 5 rpm also my CEL comes on
Old Dec 26, 2004 | 01:35 PM
si_eater's Avatar
i have a question they say the eids is the last thing to go in the wiring chain if you have a fuel comp. which side is the last the side closest to the ecu or the sensor? and does the white go closest to the ecu or the yellow. i put my eids after the afcII closer to the ecu and the yellow wire going to the ecu and the white goin to the sensor. now when my car is cold it idles bad till it warms up then it still does the drop when i let go of the gas coming to a stop not as bad as before. and what is that little screw on the back do help please
sorry if you already answered this thanks guys
Old Feb 7, 2005 | 04:28 PM
hksevo7's Avatar
My Car Still Stalls Does Anyone Elses, Or Idle Real Hard, It Sounds Like I Have Huge Cams.
Old Apr 6, 2005 | 07:40 AM
DCSilvrEvo's Avatar
My Car RUNS PERFECT man.... You might have something hooked up wrong. I used what Co EVO did and it works perfect. No stall maybe a little bog here and there but i havent tuned the EIDS yet anyways
Old Apr 6, 2005 | 07:48 AM
rraulston's Avatar
Why are you guys using this??? MY gt35r stalls the car everytime i stop. Would this help solve my problem??? Thanks Desperate for help...........Ray
Old Apr 6, 2005 | 07:50 AM
DCSilvrEvo's Avatar
Yes it will if you are Venting to the Atmosphere. It basically stoped my car from stalling everytime i stoped at a light or was backing into a space.
Old Apr 6, 2005 | 07:51 AM
rraulston's Avatar
Oh, and would this work with my UTEC???
Old Apr 6, 2005 | 07:53 AM
DCSilvrEvo's Avatar
Yea!!! It will be located after your fuel control. It hooks to your Throttle, MAS Air, and power and it starts working from there.
Old Apr 6, 2005 | 09:06 AM
sgplancer's Avatar
I highly doubt that this will work with the UTEC. The whole idea around the EIDS is that it alters the MAF signal to the ECU to 'fool' the ECU in thinking that there correct air flow/volume is being achieved when the DV is venting.
If you were to place this inline with the UTEC, the UTEC will be getting false readings and making further changes to what the ECU sees. Basically MAF--->EIDS---->UTEC----->ECU. This could lead to a lean condition, as the EIDS is just 'fooling' the ECU into thinking that there is less air, so less fuel is in order.
The other route of switching places with the EIDS and the UTEC may work, but you then will alter the reverse signal from the ECU to the UTEC. For your stalling issue, just mechanically up the revs on idle, and adjust the fuel trims accoringly. There is a lengthy post in the UTEC sub-forum. Just my .02
Old Apr 6, 2005 | 09:10 AM
vletnguyen's Avatar
i used it with the utec.. it worked great. i spliced into the harness of the car tho.. not the utec's harness.
Old Apr 6, 2005 | 10:15 PM
rraulston's Avatar
All i need is a Hz floor of about 35Hz. Why would it matter where it was spliced???
Old Apr 7, 2005 | 01:27 PM
vletnguyen's Avatar
i guess because it alters the reading before it gets to the utec or ecu ?
Old May 6, 2005 | 07:00 AM
whiteEv0boy's Avatar
Is anyone still working on the installation guide? I need one really bad. Thanks
Old May 18, 2005 | 10:45 AM
Matthew333's Avatar
eids
this thing sucks..... I hooked it up (right)and my car still idles like doo doo. I am going to buy the dam emanage and use the clamp volt option-
Old May 21, 2005 | 11:46 AM
Soon2BEVO's Avatar
I really want to run a Tial BOV which has no option of rerouting so my question is this. OTHER than idle... how will the car run, because that can be fixed with the EIDS! But what about inbetween shifts and such?
