Installed helix test pipe, need help!
Old Jul 5, 2004 | 12:37 PM
ZeroFrost's Avatar
I just installed the helix test pipe with mechanical fix. I know i didnt cross wires, cause i cut them 1 by 1 and reroute them. About 140 miles later, SES light comes on, what could be the problem? Oh by the way, I have a full turbo back exhaust, will be posting a sound/video clip, it sounds AMAZING!
Old Jul 5, 2004 | 02:20 PM
LUISC95GST's Avatar
Do you have the whole Helix exhaust steup....
Old Jul 5, 2004 | 04:08 PM
w8tless1's Avatar
has your car stalled yet? if it does you blew a 20 fuse and your wires touched the xhaust. had to make a bracket so that wouldn't happen again
Old Jul 5, 2004 | 04:13 PM
ZeroFrost's Avatar
no not the whole helix setup, just the cat delete and cat back. no it has not stalled.
Old Jul 6, 2004 | 07:47 AM
ZeroFrost's Avatar
anyone?
Old Jul 6, 2004 | 07:43 PM
bbbwrx's Avatar
Get the perrin fix. You instakk it inside the cabin and it has a light telling you if it is working. And with a mechanical fix there should be no wire cutting. I dunno if I am missing something i am not familiar with the helix cat pipe
Ben
(edit)N.M the wire extensions right? i just thought about that. get a ohm meter and check you connections and make sure they are good.
Old Jul 6, 2004 | 09:03 PM
ZeroFrost's Avatar
bump anyone else?
Old Jul 7, 2004 | 07:31 AM
EvolvedDSM's Avatar
Have you gotten the code read or are you just assuming it is from the Helix pipe?
Old Jul 7, 2004 | 09:31 AM
LilJapnBoy's Avatar
How did you extended the wires to the new location? Did you solder or crimp? My guess is that one of the rerouted wires have become loose and lost connectivity to the other end.
I have a UR test pipe which has a really similar setup. I soldered the wires one by one, electrical taped them up individually, and then taped them up all together. Make sure you didn't bend the wires up too much as well when you relocate the O2 sensor since the bung is at a different direction.
Old Jul 7, 2004 | 09:59 AM
ZeroFrost's Avatar
i used solder, then electric tape. Im going to get the code reading today. Ill let you know.
Old Aug 2, 2004 | 01:20 AM
ZeroFrost's Avatar
its coming from the O2 sensor from the O2 housing, i got the race one from Lancershop.
Old Aug 4, 2004 | 06:58 PM
hel_if_ino's Avatar
hum.. i had the same problem, i installed my helix test pipe along with the helix dp, and the apex n1 catback. I didnt recieve any codes for about 175 miles, then just today i got the code twice already, and cleared it twice (p0138), any ideas as to why this might be happening, electrical connection is sound, so i dont think thats it..??!
Old Sep 13, 2004 | 10:32 PM
JeansandJacks's Avatar
i just bought the test pipe today and reading this is like a horror story. i thought the mechanical fix was a sure thing then i found out you need to extend the o2 sensor which i thought was no biggie but it seems like everyone is getting codes. has anyone had good experiences with this test pipe???
Old Sep 13, 2004 | 10:42 PM
evo81's Avatar
i still get a ses with mine also . i think i might have the blacks criss crossed but i'm not sure.i'm starting to think this wasn't a fix for a ses.
Old Sep 13, 2004 | 10:53 PM
hel_if_ino's Avatar
no problems since that last post of mine, it was an isolated incident and has since been fixed.. i love this product.
