Oil change
Old Jun 19, 2005 | 10:51 AM
badbrain's Avatar
The oil probably never completely drains out, which would explain overfilling if you put back in 4.75 qts.
I have a question, when installing the crush washer, which side does the side with the "seam" go? Does it matter?
Old Jun 20, 2005 | 06:52 AM
QAT-R's Avatar
How is that possible? I let the oil completly drain out.
According to the instructions the side with the seam goes to the oil pan.
Old Jun 20, 2005 | 12:05 PM
mdosu's Avatar
he's just saying, make sure you car is level when you drain and fill.
Old Feb 12, 2006 | 11:41 AM
Chamama's Avatar
Is it necessary to change the crush washer with every oil change?
Old Feb 13, 2006 | 12:12 PM
brooks1005's Avatar
I was going to ask a similar question.I know people say to go buy one because they're cheap.$3 per washer at Don Herring in Plano ,Texas.I believe thats what they charged me.That's not really cheap.I remember some people saying the washer came with the filter.I was wondering how long they last.I seem to think they last about two oil changes.
Old May 5, 2006 | 02:44 PM
xenoturkey's Avatar
Does anyone have the size on that crush washer? I live pretty far from any mitsu dealerships but I have a specialty tool place that can supply me with it, I just need to know what size.
Old Jun 26, 2006 | 07:08 PM
su37su's Avatar
the link does not work for the oil change.
Old Jun 26, 2006 | 10:27 PM
NEW2006EVOIX's Avatar
When you drain your oil, you never drain it completely. There are always (at least in my other cars) pockets that the oil pools in (like in the head surrounding the cams. When you get your cams changed (or know someone getting it changed), take a look under the valve cover. After a engine rebuild, then I'd think it will take 4.75 quarts to fill. Someone can verify this that has more knowledge on the 4G63 engines.
Old Jun 26, 2006 | 10:46 PM
machron1's Avatar
Normally it only takes ~4-4.5 quarts for me. I just dump in ~4 quarts, check it, then add as necessary. A little overfilling won't hurt, especially if you do a lot of high-g cornering. A lot of overfilling can blow seals.
Old Jul 11, 2006 | 10:34 PM
XK120's Avatar
bump for fixed link
Old Jul 18, 2006 | 09:09 AM
su37su's Avatar
Fix link pls
Old Jul 18, 2006 | 03:56 PM
kmcknight's Avatar
http://www.norcalevo.net/index.php?o...2&topic=1765.0
The pics are gone though...
Old Jul 21, 2006 | 03:28 PM
XK120's Avatar
thanks! could somebody just post a pics of the oil drain? also I know this is really newb question but could somebody also tell me the best places to place the jack and jack stands? thanks
Old May 24, 2007 | 08:31 AM
TBSE's Avatar
the link it doesnt work
Old May 24, 2007 | 08:43 AM
hksevoix's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=215938
vtluu
74
Dec 28, 2015 01:01 PM
evodood
Dec 24, 2008 09:27 PM
vtluu
Apr 12, 2004 09:54 PM
evo_dadi
West Region
Dec 3, 2003 06:57 PM
