AEM Tru-Time Cam Gear and HKS Installation tuned by Vishnu.
Old Aug 27, 2004 | 12:38 AM
ryans's Avatar
AEM Tru-Time Cam Gear and HKS Camshaft Installation tuned by Vishnu.
Article by Ryan Smith and Craig Hardy. It was a fun installation and I learned a lot. Not super technical but shows how to install these products.
http://www.streetracing.org/home.php?op=go&id=1072
Old Aug 27, 2004 | 03:41 AM
4ce fed's Avatar
Not sure, since I've never done it before, but why do the cams have to come off to install the cam gears? I didn't see the point of it in that write-up.
Old Aug 27, 2004 | 04:57 AM
VTECH8TR's Avatar
Nice writeup .
Old Aug 27, 2004 | 05:17 AM
93civEJ1's Avatar
very nice write up. Now someone needs to tell me how hard it will be just to do the gears since Ive already got the cams in. Gears will be one of the next tasks.
Old Aug 27, 2004 | 08:50 AM
ryans's Avatar
We put in HKS Cams. I'll look over the article again to make sure that's clarified. Hope it helps out!
Old Aug 27, 2004 | 11:24 AM
4ce fed's Avatar
Oh, my bad. I just saw the cam gear part in the title. Maybe I should pay more attention!
Old Aug 27, 2004 | 02:32 PM
VTECH8TR's Avatar
Well since you did the cams, it should be just as easy. Just take your time and watch that the belt doesn't skip a tooth.
Old Sep 2, 2004 | 05:59 PM
ob4's Avatar
ob4
great write up and nice pics too! i can see my car on the dyno on one of those pic btw, very good dyno numbers! have you tried other cam gear settings?
-ob4
Old Sep 3, 2004 | 12:12 PM
93civEJ1's Avatar
do we put the 0' mark from the cam gears on the same exact place that the factory 0' was at too? I have been told to install the cam gears 1 tooth off??
Old Sep 3, 2004 | 02:22 PM
ob4's Avatar
ob4
vishnu cam gear comes with a red dot which is about 1 tooth to the left of the 0 degree mark (if i remember correctly). So you need to line up the red dot with the valve cover markings then everything will be fine, regardless what you see your cam gear offset to. Also, make sure that you line up everything b4 inserting the tensoner tool. The crank has also has a marking indicating that cyc#1 is at tdc.
-ob4
Old Sep 3, 2004 | 02:38 PM
93civEJ1's Avatar
im still totally confused...I have been speaking with andrew at Dyno4mance, and he told me that stock cam gears are 5 degree's off. So i need to retard both AEM cam gears -2, and then make a mark somewhere..I guess vishnu's already come setup like that??
Old Sep 3, 2004 | 03:54 PM
ob4's Avatar
ob4
Sorry i forgot that you have the aem gears... and they don't have the red dot like vishnu gears. I have borrowed the aem cam gear pic, so the following is what you can try...
1. Set your aem cam gears to zero degrees.
2. If you have a stock gear available, lineup the cam shaft key hole on the aem gear to the key hole on the stock gear. Also make sure that all the tooth lines up.
3. Find the marking on the stock cam gear, and transfer the mark to the same tooth on the aem gear. (since your aem gear is at 0 degree, everything should line up).
4. Now make the adjustment that you want on the aem gear (since you've already transfer the proper markings from the stock gear on to the aem gear, you will not have to worry about the gear timing)
5. Install the aem cam gears using the mark you've made in #3 to line up to the valve cover.
-ob4
Attached Thumbnails AEM Tru-Time Cam Gear and HKS Installation tuned by Vishnu.-normal_img_6618.jpe
Old Sep 3, 2004 | 09:38 PM
93civEJ1's Avatar
well i installed them...Please view the Camshaft reference mark thread.
Old Oct 1, 2004 | 07:42 AM
UncleXSO's Avatar
Wanted to say that I have been a long time follower of the forum, but this is my first time posting. Feels good to be doing something worth while enough to the EVO to actually post a question here.
Has anyone installed just the cam gears (minus the cams)? Is it necssary to pull the valve cover off and hold the cam still or can you get away with putting the car in gear or something to keep the engine from rotating as you loosen the cam gear bolts? I don't have a problem pulling the valve cover off, but if I can get away with not having to I won't. Saves a little time and money on the replacement gaskets.
4g63girl
Feb 15, 2011 08:50 PM
tunedbycft
Southeast Region
27
Oct 22, 2009 09:46 AM
BlackTrack
Oct 1, 2009 11:43 AM
BlackTrack
Automotosports - Illinois
13
Aug 12, 2009 09:40 AM
poknatcha
Jan 26, 2006 06:10 AM
