Nifty brake cooling ducts
Well here is a cheep way to cool down the calipers and rotors.
1- remove caliper
2- remove rotor
3- remove rear backing plate
4- go to home depot and buy 2.5" vacuum hose and floor nozzle.
5- look at photos
6- it all cost $35.00 and works great!!!!
1- remove caliper
2- remove rotor
5- look at photos
1- remove caliper
2- remove rotor
5- look at photos
1- remove caliper
2- remove rotor
5- look at photos
Hmm, looks like you might have owned a DSM before your EVO.
I was surfing the Lancer Register the other day and I saw someone use something similar to this to cool their brakes.
Here's another DIY solution: DIY brake cooling solution
the reason to remove the rotor and caliper is to remove the backing plate behind the rotor. this covers the rotor. it traps all of the heat.the hose can now cool the back of the rotor and caliper.
Are you using the aluminum LCA as a jack point?
But to critique what looks like a good idea I think you need to get the outlet of that duct work a lot closer to the caliper/rotor. You should also try putting the inlet of it ducting in an area with a greater high pressure zone. Also work on "hiding" the ducting from exposed air to prevent increasing drag underneath the car. That can be a bad place to create drag/turbulence.
I'd try something more this route: http://www.otcevo.com/brakeduct.asp
or you can get the ones straight from mitsu when you buy the car and not have to worry about robbing the air from your oil cooler and putting cheap looking hoses under your nice car
might have to look for options now. Nice DIY mods though! good job!
