Replacing the Alternator?? I unbolted it but can't get it out?
Old Nov 14, 2007 | 12:39 AM
Boost3dxEvO's Avatar
I unbolted the alternator all the way.. and just need to know how to get it out? You can't feed it through the top because there is not enough room.. and everything is in the way on the bottom.
Please help.. I really need to get this out because it is fried and need to replaced ASAP
thank You!!!!!
Old Nov 14, 2007 | 07:13 AM
cfdfireman1's Avatar
From the shop manual. Have fun.
<<C>> GENERATOR REMOVAL
Raise the engine with a floor jack and remove the generator
upward from the engine room.
Old Nov 14, 2007 | 07:17 AM
DSMorBUST's Avatar
i take it by "generator"... you really mean the "alternator" ?
Old Nov 14, 2007 | 07:26 AM
I don't "mean" anything that's right out of the manual.
Old Nov 14, 2007 | 07:27 AM
DSMorBUST's Avatar
oh wow.......... interesting... sounds like a fun job.. good luck to the OP!
Old Nov 14, 2007 | 07:50 AM
It will be fun yes.
GENERATOR ASSEMBLY
REMOVAL AND INSTALLATION M1161001400429
CAUTION
If the vehicle is equipped with the Brembo disc brake, during maintenance, take care not to contact
the caliper with tool or parts, because the caliper paint will be scratched.
Pre-removal Operation
• Under Cover Removal (Refer to GROUP 51, Front
Bumper P.51-2).
• Strut Tower Bar Removal (Refer to GROUP 42, Strut
Tower Bar P.42-12).
• Crossmember Bar Removal (Refer to GROUP 32, Engine
Roll Stopper and Centermember P.32-7).
• Front Exhaust Pipe Assembly Removal (Refer to GROUP
15, Exhaust Pipe and Main Muffler P.15-25).
Post-installation Operation
• Front Exhaust Pipe Assembly Installation (Refer to GROUP
• Crossmember Bar Installation (Refer to GROUP 32,
Engine Roll Stopper and Centermember P.32-7).
• Strut Tower Bar Installation (Refer to GROUP 42, Strut
Tower Bar P.42-12).
• Drive Belt Tension Adjustment [Refer to GROUP 00, Main-
tenance Service − Drive Belts (Check Condition) P.00-37].
• Under Cover Installation (Refer to GROUP 51, Front
Bumper P.51-2).
Old Nov 14, 2007 | 09:57 AM
joseph k's Avatar
i assure as i have done this before it is much easier to remove the passenger wheel and hub assembly half shaft and take it out that way. check your fuse on the battery terminal first and make sure it is the alt.
Old Nov 14, 2007 | 10:01 AM
sabastian458's Avatar
you can take it out from under the intake manifold, under the throttle body and thru where the battery sits.
Old Nov 19, 2007 | 11:31 PM
thanks.. i took it out this way ( :
mine was FRIED
Old Nov 20, 2007 | 05:12 AM
jmartinez1170's Avatar
Originally Posted by cfdfireman1
It will be fun yes.
GENERATOR ASSEMBLY
CAUTION
Bumper P.51-2).
Tower Bar P.42-12).
Tower Bar P.42-12).
Bumper P.51-2).
You sure dont have to do all that. Ive done this job i can do it in a 1/2 hour now.
The easy way to take out once everything is unbolted is to take out dipstick, take off the fuel rail just lift and set to the side. And it sould come right out.
Dont pm me how to do it im sick of telling people how to take it out.
Old Nov 20, 2007 | 09:08 AM
bbbwrx's Avatar
I was able to take it out through the bottom behind the crossmember with the downpipe removed.
I have a 03 though so I do not have the ACD which may make a difference
Old Jan 20, 2008 | 07:28 AM
MadCrix's Avatar
yup had to remove down pipe and axle. it popped out very easy after that
Old Jan 21, 2008 | 01:36 AM
Jameson_IXMR's Avatar
Oh god, Im doing this next weekend..... I thought it would be easy cheese....
Old Jan 21, 2008 | 02:32 AM
Billy@EnglishRacing's Avatar
alot harder then it was on a 1g, but still not the worst job ever
Old Jan 21, 2008 | 02:44 AM
The worse job ever is removing the power-steering pump mated to a Turbocharged 350 crammed inside a 94 s-10 !! Trust me on that one.
(well reguarding small engine accessories, nothing is worse than engine removal)
