Replacing the Alternator?? I unbolted it but can't get it out?
Old Jan 27, 2008 | 11:36 AM
Johnboy1065's Avatar
Originally Posted by joseph k
i assure as i have done this before it is much easier to remove the passenger wheel and hub assembly half shaft and take it out that way. check your fuse on the battery terminal first and make sure it is the alt.
thats exactly what I did. It was MUCH easier than taking the whole intake manifold and everything off the car.
Old Jan 28, 2008 | 04:01 PM
KeithD's Avatar
This is the link to the service manual, I hope this helps..
http://www.ne-evos.net/data/2003serv..._starthere.pdf
Old Apr 22, 2009 | 04:18 PM
pjsevo8's Avatar
How much fluid did you guys lose from the TC from taking the half shaft out? I am going to do this but need to know if I should pick up some Diaqueen.
PJ
Old Aug 13, 2010 | 05:34 AM
keath's Avatar
I am having hard time getting it out too. Alternator is already off the belt and loose.
got the wheel off.
so not the hube assembly and the half shaft?
Can i get some help on how to do that.
thank you
Old Feb 6, 2011 | 04:39 AM
army.engineer's Avatar
i replaced my alternator not too long ago, it was a pain. mine came out through the bottom of my evo 8. took of tire,rotors,calipers,and loosened the axle and took off from the transfer case side in order for it too be able to come out. i had a bar under the car so took that off as well. good luck for next evo owner doing this. if you have a lift it would be easier.
Old Feb 19, 2011 | 08:41 AM
MarkS's Avatar
+1.... I also took out the axle ... loosened the exhaust at the test pipe just enough to wiggle it and inch or so.... removed the bolt from the passenger side motor mount and raised the motor up about 3 inches... be sure to remove your battery so the motor has room to tilt... my battery is right next to uicp so I had to.... I have a K brace under mine that had to be removed too.
After that you should be able to give birth to an 8lbs alternator out the bottom of the car.... make sure you buy a good alternator too..... I got a cheap one that made that battery light flicker at idle... lesson learned...
Mark
Old Feb 19, 2011 | 05:33 PM
JKnapp888's Avatar
Same here man. That is the "easiest" way to get that SOB off.
Fox5.56
Sep 1, 2014 05:12 PM
LacouK600
26
Nov 19, 2012 05:42 PM
qubit
Nov 18, 2012 11:50 AM
MyRoN
04-06 Lancer Ralliart How To Requests / Questions / Tips
Feb 11, 2008 09:33 PM
AvatarOfWar
Automotosports - Illinois
Aug 29, 2003 03:31 PM
