Negative Battery Terminal
Old Aug 21, 2014 | 09:23 AM
Fox5.56's Avatar
I replaced the Negative Terminal because it was cracked. The Wire was not long enough being bolted to the body, I unbolted it and it reaches, but does that need to be bolted there?
PS. All threads I searched had no answers...
Old Aug 21, 2014 | 10:19 AM
MRolla's Avatar
No it doesn't need to be bolted there but if you make a new place to mount it you need to clean off the paint and make sure its a good ground. If not you will have other problems.
Old Aug 21, 2014 | 10:28 AM
Fox5.56's Avatar
Ill just leave it then thanks!
Old Sep 1, 2014 | 05:12 PM
DarkEvoSe's Avatar
i have the same issue and was thinking about cutting off the terminal and soldering another piece of wire (similar/same gauge) with a ring terminal on it so it can reach, thoughts/ideas/opinions? not really sure what to do about it.
TxFAkuma
13
Jun 22, 2016 08:53 AM
Pal215
10
Jan 19, 2016 04:23 PM
marinejensen
Dec 3, 2015 03:35 PM
EvoIXMR
Jul 30, 2006 07:53 PM
