help with mbc
Old Dec 31, 2007 | 07:44 AM
evoDON's Avatar
help with mbc
i just installed my downpipe, test pipe and mbc. i looked it up on a how to install the mbc and i did it just like it said to. The problem is that i am only boosting at 12 lbs, and worse is that sometimes it decides to shoot to 29-30 lbs and will stay there if i don't get off the gas. i installed the wastegate part that is perpendicular to the actual boost controller to the wastegate, and the barb that is even with the boost controller to the j pipe off of the turbo. the hoses going to the stock boost solenoid got plugged as well as the one on the intake.
what could possibly be wrong? i can control my boost with a mbc?
Old Dec 31, 2007 | 07:49 AM
evoDON's Avatar
bump for help
Old Dec 31, 2007 | 07:53 AM
[EVO]Cookie's Avatar
It sounds like you have your hose backward.
Old Dec 31, 2007 | 08:07 AM
evoDON's Avatar
no unless the guy that posted the how to did it wrong. i have the one right off of the bottom of the mbc to the turbine outlet nipple and the one off of the side of the mbc to the wastegate actuator nipple. i plugged the hoses to the wastegate solenoid.
Old Dec 31, 2007 | 08:13 AM
newbieEVO8's Avatar
See if you can get a picture of your setup.
Old Dec 31, 2007 | 09:12 AM
cfdfireman1's Avatar
Sounds like you have it right. What kind of controller do you have that may be the problem?
Old Dec 31, 2007 | 10:02 AM
evoDON's Avatar
i figured it out, when i connected the controller i did put the hoses backwards, stupid of me becuase i was rusing and stressed. nothing was going right and the one bolt for the downpipe striped out the o2 housing so now i have to figure out how to get a nut and a bolt on it. Thanks evo cookie. i checked it again today and they are backwards. noobie mistake. thanks for all the help guys and helping my car progress
