Where is the MR gauge install on a non MR thread at?
Old Jan 4, 2008 | 11:59 AM
eligh2's Avatar
Can someone post a link to a step by step MR gauge install or is it just that easy? I am picking up a set of MR gauges and was wondering how to install it on my evo IX. Can someone help me out? I have been looking through the boards for a while now.
Thanks
Old Jan 5, 2008 | 06:45 AM
Jameson_IXMR's Avatar
I have an MR and I removed the gauges so I get the idea of how they work. Theres a jumper in between the radio plug and the car plug that taps all the required power wires and what not, and theres a boost source line that runs from I dont know where, Im sure you can figure that part out. Getting power to it should be easy though, the voltmeter only needs power, the boost takes power and vaccuum and the other one has a transmitter wire to it. forgot what the other one even was lol. But I remember it had another wire I just capped and tied to the back. It should be really easy. Hope that helps. I can take a pic of the harness I ripped mine out. Wait a sec Ill update with a photo.
Old Jan 5, 2008 | 06:47 AM
RussellM's Avatar
Plat Vendor
Shoot me over an email @ russellm@brucetitus.com and I send you a .pdf of the installation instructions. That may help clear it up a little.
Old Jan 5, 2008 | 06:54 AM
Here you go. One white plug goes to the radio, the other to the cars radio plug, that terminal lug (black) gets grounded to a bolt in the radio console. There are 3 tan clips that go into each gauge, so you really cant mess it up. The 2 wire clip is volt, the 4 wire is temp, and the 3 wire is boost? I think thats accurate. I labeled them but its hard to read now. You probably just have to run a vaccuum line, Im sure the stock kit comes with the T-fitting and hose.
Old Jan 5, 2008 | 06:57 AM
Actually, if your picking up a set of these gauges from a dealer, Ill give you mine for like 10 bucks+shipping, unless your in FL, just come and take it free. It was only installed for about 15 miles from the dealership home.
EvoBroMA's Avatar
the oil temp sender replaces the stock drain plug.
Old Jan 5, 2008 | 07:01 AM
Indeed hes right, I just went out and checked it out. Never knew that lol. Iv had wiring to the cabin from my oil drain plug this whole time for no reason.
Old Jan 5, 2008 | 12:09 PM
eligh2's Avatar
MR gauges
Wow! 10 Bucks? Consider it sold. Do you have any pictures of them? Is the harness and the vacuum connection going to be included? What's your paypal?
Thanks
Old Jan 5, 2008 | 01:07 PM
PM'd
Old Jan 5, 2008 | 01:20 PM
RussellM's Avatar
Plat Vendor
And you got free installation instructions! Pretty awesome deal!
Old Jan 5, 2008 | 04:30 PM
eligh2's Avatar
Thanks RussellM !!! I just opened the link and the detailed instructions are great! You should post these in the Do It Yourself section! Thanks
Old May 22, 2008 | 11:58 AM
JJsEvo8's Avatar
Where Can I find this? I have the rest of it installed
Old May 23, 2008 | 10:36 PM
RussellM's Avatar
Plat Vendor
Are you asking where to find the drain plug/temp sender?
Old Mar 6, 2009 | 11:35 AM
RallyDSM's Avatar
Veteran: Army
Yes... where?
I've been searching all over EVOm for this information....
1 - There are two bullet plugs from the temp gauge that don't have a place to go in a non-MR EVO 8/9... one is white and the other is white with a blue stripe.
2 - Where do you run the vacuum line?
3 - is there any order as to which YELLOW plugs go where, or is it just color to color hookup, doesn't matter?
Scott
Old Mar 6, 2009 | 06:28 PM
RallyDSM's Avatar
Veteran: Army
Follow up...
After spending over 2 hours at the parts counter today, I've discovered that NOBODY at Mitsubishi can tell me what or where to get the oil temp sender or the oil pressure sender that I see most guys installing in the Oil Filter Housing.
I'm fed up with these FACTORY Gauges. Aftermarket is EASIER and CHEAPER!!!
Scott
