Change dash gauge lights
Old Jan 14, 2008 | 03:58 PM
Dgenx97's Avatar
One side of my gauges the light went out and now the only light that works is the one on the left behind the spedometer. Anyone know how to change the bulbs in the guauge cluster?
Thanks
Luke
Old Jan 14, 2008 | 04:44 PM
colonelfox's Avatar
I just did this myself. It's really easy. There are 2 bolts underneath the top of the shroud around the cluster. Remove them, and carefully pull the shroud out. Behind that is the cluster itself held on by 4 bolts, 2 on top and 2 on the bottom. Take those out. The hardest part is carefully working the cluster out to a point where you can remove the harnesses. There's 2 of them. Just remove them like any standard automotive harness and push the button thing until they will slide off freely. On the back of the cluster you can see the bulb holders. They're black and grey. Twist them and pull them out. Replace them as necessary. I ordered the bulbs from the dealer because noone had anything similar in stock. Can't remember the part number off the top of my head, but they were cheap. The whole job shouldn't take more than half an hour tops.
Old Jan 14, 2008 | 05:59 PM
Dgenx97's Avatar
thanks for the help. As soon as I find bulbs I can change them out.
Old Jan 14, 2008 | 06:42 PM
Red_KY_Evo's Avatar
part # mr444537....just ordered for mine...again
Old Jan 17, 2008 | 07:37 PM
Jameson_IXMR's Avatar
Where do you get oem fit color bulbs?
Old Jan 17, 2008 | 08:26 PM
soldi3rappl3's Avatar
Where can you get blue bulbs if its possible?
Old Jan 17, 2008 | 08:36 PM
EVOlution561's Avatar
where can you get these oem bulbs?
Old Jan 18, 2008 | 07:39 PM
colonelfox's Avatar
This is where I get all my OEM parts normally. I know most of the people that work there and they're very reputable.
http://www.trademotion.com/partlocat...&siteid=214828
The part # search doesn't work right yet, but it looks like the bulbs are in the instrument panel section.
Old Jul 7, 2008 | 02:00 PM
Hen5000's Avatar
Is the stock Oem bulb that's behind the odometer white? Trying to get mine replaced under warranty, and long story short they were giving me the run around.
Old Jul 7, 2008 | 02:05 PM
colonelfox's Avatar
The odometer is an LED display. I didn't think it had a light.
Old Jul 7, 2008 | 06:18 PM
Hen5000's Avatar
O crap.. cause the light behind my odometer is so dark. I thought it's just a light bulb cause during the day it's fine jsut night i can't see it.
adammartini
Aug 1, 2009 12:38 PM
lanceritis
Oct 18, 2007 02:35 PM
avo3vom
Aug 12, 2007 08:56 PM
wrcwannabe
May 23, 2007 05:45 PM
02Lancer
Jan 6, 2004 08:07 PM
