Need Help installing sparco 4 point harnesses
Old Jul 13, 2008 | 11:52 AM
ModifiedMR's Avatar
I was searching for a while and I can only find threads asking how to install, but the threads have no answers. So here is the situation. I have sparco 4 point harnesses but no harness bar. I plan to get one but no right away. So until then where do I mount the harnesses to? Answers are appreciated and any pics you might have would be great thank you.
Old Jul 14, 2008 | 05:19 AM
ModifiedMR's Avatar
Monday morning bump.
Old Jul 15, 2008 | 04:34 PM
ModifiedMR's Avatar
Tuesday night bump
Old Jul 18, 2008 | 08:17 AM
jusa4cyl's Avatar
When I installed mine I took out the seats. Bought some steel bars then drilled out the seat bolt hole and drilled out a hole for the eye bolt for shoulder harness belt connection. Installed the supplied eye bolt with a lug nut onto the steel bar. Then put the bar on the seat bolts. Then for the lab belts I used the stock seat belt bolt beside the seat close to the floor, by the door on the pillar. I then tucked the factory belts behind the plastic. and the other side connects to where the factory lock connects to the seat. You will have to remove the the lock mechanism from the seat or you can also connect the lap belts to the bracket you made with eye bolt in it, depends on how tight you need them. Reinstall the seats. Run the shoulder belts through the holes in the seat back and run them under to the eye bolts. will take a little time but its pretty easy. Mine work perfect and are safer than the factory ones.
Old Jul 18, 2008 | 12:52 PM
talentsearch301's Avatar
http://www.schrothracing.com/sdocs/S...Three.Fold.pdf
hope this helps
https://www.evolutionm.net/forums/sh...55#post5904355
kevin salazar
Evo X How Tos / Installations
Oct 22, 2016 11:40 AM
ForgivenEvo
11
Mar 2, 2008 04:11 AM
haze1995
Northwest Region
12
Feb 11, 2008 12:41 AM
V8eatr
Oct 25, 2007 10:35 AM
kingkyle
Jan 10, 2005 01:56 AM
