help installing thermostat?
Old Jul 16, 2008 | 11:13 AM
downshift411's Avatar
im having cooling issues. ill drive the car for half hour and the car will over heat. so i stop and let it cool down it goes back up. if i take it for a drive it easily cool down to normal temp...? so at idle its not cooling at all. changing the thermostat is the next option. i flushed the coolant and replaced with new coolant etc.
anyone know how to change it or have done it before?
also does anyone know if the evo 4/5/6 thermostat is the same as evo 7/8/9?
Old Jul 10, 2009 | 07:43 PM
evo9ben's Avatar
does anyone kno how to do this
Old Jul 11, 2009 | 11:23 AM
Evokid8's Avatar
evo9ben on the 8 its real easy....
-remover upper hose and take out the housing there are 3 bolts 10mm i believe
-once the housing pops off the thermostat will be right in front of you, just pick it out
-and put the new one in and MAKE SURE you seal the housing with high temp silicone for leak free install
-bolt it back up and bam
Old Jul 11, 2009 | 11:26 AM
Macaroni's Avatar
^ This. Also make sure the little "dangly thing" sits at the 12 oclock position when you put the new one in. I'm not sure what its called but its a little bleeder for any air that might get trapped in the system.
bjackson
15
Sep 20, 2014 05:36 PM
SmurfZilla
34
Jul 16, 2013 06:48 AM
<mojo>
Lancer Troubleshooting
12
Nov 12, 2012 02:07 PM
JamaicanEvo
19
Nov 26, 2010 06:55 PM
56Hotrod
Jun 26, 2007 06:09 PM
