Walbro 255 help
Old Aug 23, 2008 | 08:12 AM
TangoASI's Avatar
Walbro 255 help
ok I installed the stock and walbro unit several times into my car and have not been able to get my car to start, it started before the install. I believe I checked all fuses and none seem blown. All wires are in an put in correctly. I can hear the fuel pump working after I try to start it. It seems that the fuel line isnt pressurizing. Anyhelp would be nice
Old Aug 23, 2008 | 08:20 AM
Psquared's Avatar
If I remember right, there is a small black o-ring kind of gasket that has to be in place above the fuel pump. When you pushed the pump up into the white plastic housing, did it kind of "snap" into place? If not, the fuel it's pushing out is just leaking right there back into the fuel tank and not pressurizing the system.
I know you did, but double check all wiring connections and fuses.
Old Aug 23, 2008 | 08:25 AM
TangoASI's Avatar
ok I gonna pull it out again and check and see if it is seated right but first is there a specific fuse that I am trying to look for?
Old Aug 23, 2008 | 08:29 AM
TangoASI's Avatar
ok so is the white thing suppose to go into the grommet
Old Aug 23, 2008 | 08:35 AM
brandon1304's Avatar
this should help!
http://evomoto.com/tech_info.php?tPa...f951f082206358
Old Aug 23, 2008 | 08:37 AM
TangoASI's Avatar
thats the install guide im using
Old Aug 23, 2008 | 08:51 AM
TangoASI's Avatar
checked all wires and the grommet and its all good,
hmm... thats odd
Old Aug 23, 2008 | 09:19 AM
TangoASI's Avatar
just checked all fuses,wires,grommets and everything is there in place as it should but my car will not start with the walbro or the stock fuel pump, seems like there is no pressure so I dont know what this could be
Old Aug 23, 2008 | 09:25 AM
Psquared's Avatar
does the car even turn over?
Old Aug 23, 2008 | 09:41 AM
TangoASI's Avatar
yes it turns over tries to idle and dies
Old Aug 23, 2008 | 12:22 PM
Dorikun's Avatar
Maybe, just maybe... try resetting your ECU buy disconnecting the battery terminal this will of course reset your stock radio presets. I'm thinking maybe the ECU doesn't understand that you installed the pump? Hm... maybe I'm totally off. Just a wild shot in the dark, I have no clue myself [noob] :-/
Old Aug 23, 2008 | 03:31 PM
Mellon Racing's Avatar
the ecu is indeed oblivious to the pump change and thus it's going to be richer until it's tuned since the fuel pressure won't be falling off like it does with the stocker on a modded car with more demand for fuel.
Old Aug 23, 2008 | 03:52 PM
TangoASI's Avatar
Hey thanks everyone got it fixed. Hey Mellon I should be getting ready to send you some logs to get that tune finished shortly.
Old Aug 23, 2008 | 04:04 PM
cool!
