Help needed
Help needed
MODs move this if in the wrong place.
I've been having problems with the driver side headlight. I have an 03' EVO 8 Replaced the bulb with some aftermarket ones then when that one went out I replaced it again but this time the headlight didn't work. I thought it was the bulb so I bought some new ones, it still didn't work. I'm trying to figure out if I need to go and get a whole new headlight or if it's something I can fix. I went and got a circuit tester to see if there was power going to the headlight and according to that there was none.It was a 6,12, or 24 volt tester so It should have been able to test the volts for the headlight. I don't know what the issue is. I've installed all bulbs correctly but for some reason Can't get the headlight to work. So was wondering If anybody had any suggestions or had this problem before and know what to do.
thanks
evoracing
thanks
evoracing
not sure what you have or havent tried but possably you blew a fuse if you had the lights on when replaceing or testing to see if the lights would work
possably a bad ground or a wire could have broken when pulling the plugg off
good luck
wow didnt see how old this thread was but hope you got it fixed
good luck
