Adjust jdm headlights
Old Sep 5, 2012 | 07:05 PM
FenixTX717's Avatar
Anyone know how to adjust the HID head lights on an SSL packaged Evo with the manual adjusting on the inside. I have them set all the way up but I'm assuming because my car is lowered the cut off points much lower than it should.
Old Sep 5, 2012 | 07:45 PM
Chef-j's Avatar
If its usdm, there is a thread you can try.
Old Sep 5, 2012 | 08:50 PM
Ryuartz's Avatar
Let me help you on this. This is only for JDM headlights. USDM is slightly different from this.
Red circle : adjust low beam up and down. You need to get right size philips screwdriver and put it into the hole where red circle is and turn clockwise or counterwise.
Yellow circle : adjust low beam side to side.
Old Sep 5, 2012 | 09:00 PM
Chef-j's Avatar
^ yey!!! Awesome!!! Thanks!!!!
Old Sep 5, 2012 | 10:00 PM
FenixTX717's Avatar
So does anyone know how to do the USDM ones? I've searched and can't find any info on this.
Old Sep 6, 2012 | 10:10 AM
Chef-j's Avatar
https://www.evolutionm.net/forums/ev...-leveling.html
Maybe this will help a little?
Old Sep 12, 2012 | 10:23 PM
FenixTX717's Avatar
Originally Posted by Chef-j
Thank you! Hopefully I can check this out tomorrow during the day with light!
Old Feb 15, 2013 | 05:02 AM
Evo11V's Avatar
Veteran: Army
So I searched and searched for this same exact thing and no matter what I saw I didnt find to work and incorrect. JDM and USDM are different but if you have JDM headlights its super simple and once I figured it out took me probably under 1 minute for both headlights.
All you need is a philips head screw driver, you'll see right by the level motor a black opening, insert the screw driver in that hole (make sure its about the same size as the hole not too small or this doesnt work) and I turned the screw driving thinking it wasnt doing anything an shocked it was raising them. Like I said took me about 1 minute for both (after 30 min of doing everything else everyone was saying). I put them all the way down first so I could raise them up with the switch for driving at higher speeds.
http://imageshack.us/photo/my-images/207/img3604.jpg/
So if you look at this image, right by the leveling motor you can see to the right of the plastic "grey" connector you see a hole about the size of a screw driver. Insert screw driver in there and turn a few seconds later you'll be done.
Old Feb 25, 2013 | 09:39 AM
Sti Killer...'s Avatar
does anyone have pictures on adjusting the low beam and also how to do the Fog lights. They are JDM lights
Old Feb 25, 2013 | 09:50 AM
Evo11V's Avatar
Veteran: Army
I explained this on the post above yours and there is a link that has a picture of what I was talking about.
Old Oct 22, 2013 | 07:38 PM
DagYo369's Avatar
Question, I see where you at just the low beams for a jdm headlight but what about the high beams? My problem is that my high beams are shiny waaay to high but low beams are good. PS I did not install these bought the car with them in.
Old Nov 9, 2015 | 10:35 PM
highbredcloud's Avatar
good info...
Old Aug 2, 2016 | 06:52 AM
kyoo's Avatar
thanks for the info guys - clockwise raise, counter, lower?
Old Aug 3, 2016 | 09:17 PM
kyoo's Avatar
bumping this - is it normal to only have a very small range of turn? mine is only going maybe 10 degrees max before stopping - do I need to force it or is that all there is? gotta imagine there's more than that..
also, clockwise raise or lower? i'm asking now cuz the headlights are off the car. They actually have a bit that sticks out that i can turn by hand.
please help!
Old Aug 5, 2016 | 08:07 AM
kyoo's Avatar
all right guys - I've got the gear turning but no change in the height - it seems like it wants to but it actually doesn't - any help here?
