No spark with hks dli2?
Im not getting any spark from my hks dli2, all i should have to do is ground it and connect the clips right? or am i missing something, never got shipped directions with it *used* any help would be great
Once the DLI II box is connected you should be able to see the red light come on on the side of it. It must be grounded well. Then, for safe measure, put some dielectric grease in the connectors and plug them tight. Check the back side of the connectors. The wires are quite thin and can easily break behind the connector. Make sure all 4 connections are snug. Make sure your coils are snug. Make sure you didn't pinch a wire under the spark plug cover.
evotris
Sep 15, 2016 03:19 PM
35rEvosilver
Oct 24, 2011 06:02 PM
Noogles
67
Sep 20, 2007 10:37 PM
ExViTermini
Sep 10, 2007 02:48 PM
