HKS DLI 2 vs Sun Hyperforce Ignition
Old Sep 28, 2006 | 07:58 PM
Noogles's Avatar
Has anyone compared the two ignition amps?
I've read the reviews for the DLI-2 but nothing on the Syn Hyperforce Ignition.
Old Sep 28, 2006 | 08:04 PM
fromWRXtoEVO's Avatar
I happen to run Hypersun on both of my Evos and they work great. It also allows me to run very high boost on the Evo 8 MR with methanol. We did a 1400 mile trip a couple of months ago and gas mileage was slightly better.
Truly plug and play. I haven't confirm dyno HP gains due to specific conditions that hinder good dyno readings(heat and elevation)
I am dynoing the car again in Phoenix at lower latitude and elevation and I would share the dyno numbers one more time.
The HyperSun is a competition product for much less, you should already know we pay a lot more for the name HKS.
Carlos
Old Sep 29, 2006 | 12:47 AM
Noogles's Avatar
Carlos how much boost are u running. I really want to know if it will hold 35psi on my 67mm turbo
Old Sep 29, 2006 | 08:19 AM
Zeus's Avatar
My understanding is that the Sun unit produces only slightly less power, at a better price point. I've yet to test this myself...
Old Sep 29, 2006 | 08:56 AM
Gusl's Avatar
HKS & Sun Hyper
I have tested both units on my car.
I had the HKS DLI2 and it ran great until it died. Its at HKS world getting fixed.
Since it died I bought a Sun Hyper Force to try it out hopeing it would work just the same.
It didnt, at least for my car that is.
With the HKS unit I was able to run 27 pounds of boost making 456HP.
With the Sun Hyper Force I was able to boost max 23 pounds before the spark blew out. Needless to say I lost alot of HP. The most I was able to do was 412 HP.
Rather disappointed to say the least.
My mods were exactly the same just changed the ignition amplifiersthe mods are are as follows-
Greddy 25G turbo kit with Type R WG
Tial BOV
3 inch full exhaust no cat
Perrin intercooler
RMR Pipe kit
255 fuel pump
Profec B boost controller
AEM EMS
Aeromotive Fuel Reg
750cc injectors
HKS 264 cams
ACT Clutch
HKS DLI 2 / Sun Hyper Ignition
ALKY Kit
I hope thats it.
Old Sep 29, 2006 | 09:32 AM
jmartinez1170's Avatar
Tial BOV
Perrin intercooler
RMR Pipe kit
255 fuel pump
AEM EMS
Aeromotive Fuel Pump
750cc injectors
HKS 264 cams
ACT Clutch
ALKY Kit
I hope thats it.
This is good info to know man i going to test it out as soon as i build my car. I have the sunauto so i hope that is not the case.
Old Sep 29, 2006 | 09:34 AM
saiyanzzrage's Avatar
Dli Ii
Old Sep 29, 2006 | 10:35 AM
Zeus's Avatar
Tial BOV
Perrin intercooler
RMR Pipe kit
255 fuel pump
AEM EMS
750cc injectors
HKS 264 cams
ACT Clutch
ALKY Kit
I hope thats it.
Interesting... I'd like to see what someone running OE engine management sees...
Old Sep 29, 2006 | 10:51 AM
DRFTKNGG's Avatar
I am running the DLI-II and I have to say that I have never had a mis-fire since.
Also I wanted to see what would happen if I stuck some denso's in staight from the box what would happen....I havent removed them since. No problems, even with no gapping. I am running methanol and I dabble around town with 26-28 Psi.
Old Sep 29, 2006 | 11:24 AM
Derek888's Avatar
NGK R7376-9 works good at 32psi with the HKS DLI. car runs perfect if this has anything to do with what you talking about...sleeping pill kicking in so my mind is out of it now
Old Sep 29, 2006 | 11:47 AM
Gusl's Avatar
HKS / Sun
I loved the HKS DLI2, it worked awesome until it died on me.
The Sun Hyper Force is really nice also. I liked the fact that it came with the ground wires and also the fuse. If the HKS had a fuse it would have lasted longer for sure.
I am now running the Extreme Motorsports COP with the AEM 4 channel. As of now its excellent and I am very happy with it. Nomisfires at high boost no spark blow outs, no nothing. I am waiting on my GT 37R turbo kit from RNR.
I hope my ignition problems will never be an issue again.
Old Sep 29, 2006 | 05:06 PM
Invoice EVO's Avatar
Veteran: Air Force
I'm using the SUN unit now. I went to the track this past Monday and it held 30 psi fine. I made over 10 trips down the track. I've also made 30 psi runs on the HKS unit with no break ups. All runs were exactly the setup listed in my sig.
Old Oct 1, 2006 | 12:56 PM
Noogles's Avatar
can ypu please take a picture of the connector that plugs into the stock harness and and the one that plugs into the coils please.
Old Oct 1, 2006 | 02:36 PM
Bom's Evo's Avatar
hks DLI2 solved my misfire and never had one since. from .22-.28 gaps. don't matter 25psi+ stocker.
Old Mar 22, 2007 | 11:55 PM
Speed Element's Avatar
Sun Auto Hyperforce System works great for me and some customers.
Here is a before and after dyno results.
All results were tested on the same day and same vehicle owned by our local member here.
Vehicle is 2006 EVO IX w/ just tanabe downpipe and hks cat-back.
Before
After
