HKS DLI 2 vs Sun Hyperforce Ignition
Old Jul 28, 2007 | 02:29 PM
  #46
EvoBig16G's Avatar
how can one tell if the HKS DLI-II igntion box is dead or not?
Old Jul 30, 2007 | 01:36 AM
  #47
haseeb's Avatar
im runnimg dli 2 and its running gr8 on 2 bars boost and gt35 r turbo
Old Jul 30, 2007 | 06:12 AM
  #48
Soon2BEVO's Avatar
Buschur himself told me not to bother with the HKS DLI because how of it's unreliability. Im glad I didnt get an ignition box. 30psi with methanol, plugs I gapped down to .023 and no misfires what so ever. Ive had some 33psi+ spikes too!
Old Jul 30, 2007 | 06:19 AM
  #49
Zeus's Avatar
...so you are running on an OE ignition then right?
Old Jul 30, 2007 | 06:28 AM
  #50
Soon2BEVO's Avatar
I am yes, other than NGK BR8ES plugs. I bought a new set of OE plug wires since when my Green went on I was at 67,000 miles already.
Old Jul 30, 2007 | 10:23 AM
  #51
Erik@MIL.SPEC's Avatar
Originally Posted by joeracer321
I would take a stab at DLI's dying due to user installation. If it were mounted too close to a radiant heat source, or a poor ground. Those types of things could cause a box to die. I have been running mine for about a year and a half with no problems what so ever.
Don't know if this would make a difference, but on my Sun Hyperforce there is a fuse between the unit and the positive terminal on the battery. I've heard the HKS DLI does not have a fuse, so there is no protection in case something wonky happens with the electrical system.
Old Jul 30, 2007 | 03:36 PM
  #52
NIevo's Avatar
Would it be possible to wire in a fuse? If so what amp would a person go with?
Old Jul 30, 2007 | 03:48 PM
  #53
TIBOevo's Avatar
how are you able to tell if the hks DLI II has died ?
Old Aug 11, 2007 | 07:11 PM
  #54
EvoTio's Avatar
I've been wanting to get an ignition amplifier for quite some time. I've heard too many comments about the HKS DLI II being unreliable. That's ashame. This reminds me of the MSD 6 multi spark amplifiers that I ran on my V-8's. They would last about a year or so and then just die! After going through several units I decided to mount the MSD 6 box inside the passenger compartment away from the heat and moisture. That seemed to have done the trick, I still have the same MSD box operating for more than 7 years now.
Old Sep 19, 2007 | 09:12 AM
  #55
timmiii's Avatar
Any updates for that dyno test between the HKs DLI and Sunauto?
Old Sep 19, 2007 | 06:53 PM
  #56
vwjeff's Avatar
So what I have gathered here is that keeping the HKS box from extreme heat, getting a good ground and mounting on a soft pad of some sort and your good?
To anyone that has had your HKS box for a while 1+ year's. How are you mounted
Old Sep 19, 2007 | 09:57 PM
  #57
APEX1's Avatar
I bought the NGK R plugs and gapped at .020 and still a misfire but, I can't feel the misfire or hear it
My engine light always comes on at idle not when Im mashing it
I need help - any ideas
Old Sep 19, 2007 | 10:23 PM
  #58
TTP Engineering's Avatar
We will be testing the OKADA PROJECTS Plasma Coils in the next few days.
Old Sep 20, 2007 | 07:20 AM
  #59
Faust's Avatar
I'm really interested in that test! Thanks and let us know your results ASAP. I've been looking at those for a while. It will be pretty Bad-A$$ if they are equal to or better than a COP set up.
Old Sep 20, 2007 | 07:26 AM
  #60
Pure Playaer's Avatar
Quick question.. How do you know if the HKS DLi dies or not? I just bought one slightly used.. and later on in the future when im running alot of boost id like to know if something happens to it.
