How to remove evo 9 climate control cluster?
this is basically a throw away unit stealthmatt. Once one of the LED's has blown it's stuffed. You may want to trade it in for a Prius, I hear those are going pretty fast in the USA at the moment
oh yes he did !
HEATER CONTROL ASSEMBLY AND A/C SWITCH
REMOVAL AND INSTALLATION
Heater Control Assembly And A/C Switch - Removal And Installation Part 1
Heater Control Assembly And A/C Switch - Removal And Installation Part 2
INSTALLATION SERVICE POINTS
>>A<< MODE SELECTION DAMPER CABLE CONNECTION
Set the heater control assembly's mode selection knob to the DEF position.
Set the heater unit's mode selection damper lever to the DEF position (turn the damper relay to the left until it stops) and install the cable.
Set the mode locator to the heater unit case and secure with a clip.
>>B<< AIR MIX DOOR CABLE CONNECTION
Turn the heater control assembly's temperature adjustment knob all the way to the HOT side.
Set the heater unit's air mix door lever to the MAX HOT position (turn the damper lever as the left illustration) and attach the cable.
---UNIT DISASSEMBLY AND ASSEMBLY---
WTB[West]: Evo 9 cluster
Paulevo9
Apr 12, 2016 08:33 PM
dsm_mikey
Mar 5, 2006 07:50 PM
iodine23
78
Dec 16, 2005 02:32 PM
