need timing help
Old Mar 28, 2010 | 05:57 PM
timmycat's Avatar
need timing help
is there any way to be able to tell if the crank is tdc with out the plastic cover that has the timing marks on it. because it is getting old having to take it off and on
Old Mar 28, 2010 | 06:16 PM
evo8nfs's Avatar
you can use the screw driver method.. pull the spark plug out of cylinder #1 and place a long screw driver in there and make sure you make contact with the piston.. crank the motor untill the screwdriver goes up. then eventually it will go back down once its at it peak in the up stroke lol it should be TDC. hope that helps
Old Mar 28, 2010 | 06:26 PM
timmycat's Avatar
okay kool, which cylinder is #1 thow
Old Mar 31, 2010 | 10:32 PM
xceler8rob's Avatar
The one on the passenger side of the motor. Screwdriver trick isnt very exact. there should be marks on the block and the crank sprocket that you can line up.
Evo3573
Jun 13, 2013 04:16 PM
5LEEPERISAH23I
Jul 14, 2010 04:52 AM
Matthew333
For Sale - Wheels / Tires
Jan 28, 2010 03:09 PM
MCarfi
Apr 7, 2008 08:58 PM
FastAzzEvo
Sep 21, 2006 02:22 PM
