How To: Another DIY Catch Can mod - Dual, with baffles and extended inlet tube
Old Apr 12, 2010 | 09:54 AM
vortico's Avatar
Very cool, glad you caught that I missed that,. I'll have to take a look and see what the thread is then so I can pick up some hose connectors, and then update the thread.
Old Apr 12, 2010 | 10:59 AM
drb's Avatar
drb
Another option is to leave the PCV Valve in the stock location and put a small check valve in the hose that runs from the catch can to the intake manifold.
This is the valve that I use:
http://www.usplastic.com/catalog/ite...6844&catid=489
Dan (drb)
Old Apr 12, 2010 | 06:13 PM
vortico's Avatar
Updated with the PCV valve move.
Old Jun 2, 2011 | 08:55 PM
SPANKED's Avatar
This thread came in handy. Thanks vortico!
Old Jun 6, 2011 | 08:38 AM
vortico's Avatar
Glad it helped!
Old Jun 21, 2011 | 08:19 PM
Joesforspeed's Avatar
great thread
Old Jul 13, 2011 | 06:39 PM
vortico's Avatar
After about 16 months I removed the catch cans when I was installing my new UICP. Much to my joy they have worked great and these are the results. 90% of this is from the PCV side.
10k miles and around 16 autocrosses since these were put in.
Old Jul 20, 2011 | 03:18 PM
killercd4G63's Avatar
Veteran: Army
i might have to do this soon.
I hope this process doesn't whoop my gr***
Old Jul 20, 2011 | 03:36 PM
hjh1176's Avatar
it looks awsome to me
thanks good post
Old Sep 14, 2011 | 08:29 AM
Locdizzel's Avatar
so you kep your old pcv in as well as adding the other one?
Old Sep 14, 2011 | 09:20 PM
vortico's Avatar
Yeah I ended up leaving the old pcv in and added another on the other side of the catch can. Eventually I'll just remove the original pcv valve but for now its suffering no ill effects having both.
Old Sep 14, 2011 | 09:37 PM
Saikou_kun's Avatar
Nice DIY! I applaud the work you put into it. I know it wasn't easy! Soldering is a PITA, but yours came out pretty good.
The color is pretty cool too!
*Maybe I would put some more scrubber material in because it seems a little loose and it might sag.
Old Sep 15, 2011 | 06:30 AM
Locdizzel's Avatar
just redid mine using your setup and the 2 pcv's made the are feel a lot better for some reason (possible boost leak from just running one i guess), awesome job thanx for the help
Old Sep 15, 2011 | 06:55 AM
vortico's Avatar
Thanks! One of these days I'll have to open them up fully so I can see how they look on the inside after all this time. More scrubber material would probably be good I just wasn't really sure how tight I could pack it without restricting airflow. Once I open it up I'll see how much the material has sagged and that should give a good baseline. Thanks!
Glad it helped . Technically you only need the relocated PCV (needs to be close to the Intake manifold to stop the pressure during boost from going to the catch can.) I would say its possible your factory one may be clogged or seized so its always open which would pressurize your valve cover during boost, doubt that would feel good.
Old Sep 15, 2011 | 07:09 AM
bonsuz01's Avatar
Nice Job Sir... and looks awesome too.
