engine tools for a rebuild
hi
i have spare evo 8 engine 4g63 that I'm going to stroke 100mm crank, rod , pistons .5 OS etc ,
so im thinking of doing the work my self on the bottom end .
what tools will i need, let say i have no tools bar hand tools
what will i need to make a good running engine tools wise
i don't mind spending money on tools as i will us them again
but if i can get them at a good price that's a plus
so can some one tell me all the bits i need to do the work and were can i
get them ?
what brands are good etc
links to the tools would be nice
I'm in Ireland so take that into mind
I'm a general mechanic by trade but have never done a high end race spec
engine like this before
thanks for any input
get them ?
so lets start here, what is good band piston ring grinder and piston ring pliers
just had look on ebay ( not the best place for tool )
this piston ring grinder
http://cgi.ebay.com/ebaymotors/Race-...Q5fCarQ5fParts
piston ring pliers
http://cgi.ebay.co.uk/50-100MM-PISTO...item5d2824129d
or
http://cgi.ebay.co.uk/Brand-New-Clar...item27b02ee90a
what tools / brands are the traders / engine builders using
piston ring pliers
or
Things that I saw that were not mentioned of fth top of my head...
Other than basic hand tools...
-Feeler gauges to check the deck flatness and piston ring gap.
-bore gauge to check cylinder bore.
-plasti-gauge strip at least to check main and rod bearing clearnaces.
-I'm drawing a blank right now on the name of the tool but something to check the end play on the crank.
-Once again drawing a blank on the tool name but the tool used to check the amount of stretch on the rod bolts.
-Flat Edge to check the deck flatness.
-Torque Wrench. Probably 2. One that goes from 5-75 foot pounds and another that goes from 50-250 or 300 foot pounds.
-Very fine grit sand paper.
-Molylube.
Sorry no links right now on tools.
Good thread idea though!
-Molylube.
-Molylube.
-Molylube.
have few sets of feeler gauges in my tool box
the tool your thinking of is dial gauge with a magnetic stand
Dial bore gauge would be nice, dial indicators would be necessary for checking end play of the crank. feeler gauges, a straight edge, ball gauges, good set of micrometers. Im sure you will find more things your need as you go. GL with the build
thanks all for the input
any one got a good place to get a piston ring file
seen one's that have hand crank
like this one, but its out of stock
http://www.speedwaymotors.com/PRECIS...ILER,2915.html
