How to replace cluster bulbs??
Old May 13, 2010 | 07:31 PM
john blaze's Avatar
the bulbs on my instrument cluster went out. how do i replace them? and where do i get the bulbs? please help. thanks
Old May 13, 2010 | 07:33 PM
adorkableVo's Avatar
remove your cluster, i think there's like 4 screws total? I had to order my bulbs from the dealer.. 3.XX each i believe...
Old May 13, 2010 | 07:43 PM
john blaze's Avatar
do you know if these bulbs are the same ones as the bulbs on hvac console?
Old May 14, 2010 | 06:21 AM
Bassicfun's Avatar
no, different bulbs...
2 screws to remove the trim, 3 screws to remove the cluster, two large plugs to unplug..
The cluster bulbs ALL went out together? very well may not be a bulb, but a fuse... just a thought for you..
Old May 14, 2010 | 06:46 AM
Bobster22388's Avatar
^+1, also when you go to remove the cluster from the dash, when you remove the trim piece, if you pop out the little dash piece to the left of the cluster it will make it much easier to get out, and lower the steering wheel of course.
Old May 16, 2010 | 11:57 AM
john blaze's Avatar
only one bulb went out. the bulb between rpm and speedo. how do i obtain a part number for this bulb?? thanks
Old May 21, 2010 | 01:13 AM
umopp's Avatar
Just wondering but will replacing the cluster bulbs also fix the dimness of the needles or do the needles have separate bulbs?
Old May 21, 2010 | 06:47 AM
Bassicfun's Avatar
the needles are illuminated by the same bulbs, brighter bulbs will make it all brighter... the issue becomes getting an 'even' lighting, rather than an unevenness of bright and dim spots.
Old May 21, 2010 | 07:24 AM
bullet_1's Avatar
I would definitely recommend getting factory style bulbs. I replaced mine with leds, and the light distribution is uneven.
Old May 21, 2010 | 07:54 AM
Bassicfun's Avatar
Only way I've seen them done and looking *good* is with multiple SMDs that distribute light sideways and forward, but the problem is the bulb length is so long, it puts the top SMD too close to the cluster overlay, and doesn't allow for even light distribution.
Old May 21, 2010 | 08:33 AM
RandomLaosGuy's Avatar
Super easy, I did this last week.
(2) screws holding trim
(3?) cluster screws
Unplug harness
Pull out the cluster (Actually the hardest part for me, I had to flip it sideways)
You'll see the bulb, just twist and replace.
Old May 15, 2012 | 06:14 PM
WResch09's Avatar
I have to change mine asap
Old Jun 15, 2012 | 02:27 PM
EdSales's Avatar
Wish we could make em brighter.
Old Jun 18, 2012 | 12:04 PM
Jschlo4's Avatar
The lights have a white cover on them. You can pull this off and it will help brighten the cluster a little bit. its not as extreme as the LED lights, but it does improve it.
My questions about the cluster is, how do you get to the Headlight light? I cant seem to get to it without pulling the back completely off. There is no access on the back like with the other lights.
Old Jul 1, 2012 | 03:17 PM
hiboost2.0's Avatar
Do you guys know what the part number for it is?
