I'm about to use a stick of dynomite to get this head off....
Old Aug 1, 2010 | 08:35 AM
evoboi005's Avatar
Originally Posted by DFelton
Alright! I have the new springs on and cams in, the head is back on the car BUTTTTTTTTTTT I may have messed up. When I put the new cams on they didn't go on the exact same positioning as the originals, aka the dowel pin on the end of the cam is at a 45 degree angle instead of straight up. I realized this after I bolted it to the block so I hope I didn't bend a valve.
I'm pretty sure its fine though, so I'm going to use a crecent wrench and slowly turn the cams to the position the need to be in, I need some way to keep them there because they want to spring back....
We'll see.
the valve springs push the cam around you have to hold it rotated to the right place and do the timing belt and make sure the mivec cam is rotated to the rear of the car
Old Aug 1, 2010 | 04:49 PM
DFelton's Avatar
I made a boo boo...
I buttoned it back together and it started right up, but now it sounds like there is loose change somewhere in the valve cover/intake/throttle body area. I can't seem to pinpoint it. It's not constant, that's why its hard to trace. I rev it to 2k and let it fall back down and it will rattle for about five seconds. I don't think its the lifters, sounds more like a washer, any ideas?
Old Aug 1, 2010 | 05:32 PM
DFelton's Avatar
After lots of searching (and after evoboi005 mentioned the MIVEC cam) it looks like the MIVEC cam needs to be primed and rotated back? I drove the car for 2 miles very gently and it ran fine, wouldn't that be enough to prime it?
How do I rotate the cam backwards? I don't reallly get it...
Thanks again for the input guys
Old Aug 1, 2010 | 07:40 PM
evoboi005's Avatar
should have primped it self in the first 10 seconds of running ...did you throw a timing over advanced code? ... if not and all the timing marks line up your prob ok
Old Aug 3, 2010 | 06:42 AM
DFelton's Avatar
I took it apart again and bled the lifters and most of the noise went away. the intake still has a strange sound but oh well. Thanks again for the help everyone!
Old Aug 8, 2010 | 06:34 PM
forc3 f3d's Avatar
that doesnt sound like something you just want to "oh well"
Old Aug 8, 2010 | 06:49 PM
vanilla2's Avatar
All of your uh oh's reminded me why I haven't messed with anything that has to do with timing on my car. I'm sure I can do it but with all of what can go bad will go bad for me
Old Aug 8, 2010 | 07:28 PM
b16a95eg's Avatar
Are you sure the noise isnt coming from your PCV valve? Mine makes a little rattle noise over there every now and then but goes away
Old Aug 9, 2010 | 08:16 PM
DFelton's Avatar
Attention!!!!! The problem has been solved and you're not gonna believe it. The car obv doesn't run well without a tune right? And it only happened at idle, so any final guesses what it was? The car didn't create enough vacuum at idle and rattled the egr valve ball which resonated throughout the manifold. Tuned the car to idle smooth and problem solved!
gasolinebaptism
Apr 20, 2016 02:04 PM
Gas'd LanOZ
Jul 30, 2013 05:52 AM
Piro Fyre
Aug 23, 2012 08:13 AM
miller121mx
Apr 9, 2010 12:03 PM
kaymin
Jan 7, 2010 10:41 AM
