FIC 2150s Install HELP!!!!
Hey Guys,
I heard it was pretty easy to instal the 2150s with the plug and play..Was wondering if anyone has done this and if you could help me out..Thanks!!
Yeah i just ordered them and realized that sent me the wrong ones..I got sent the pigtails not the plug & Play that i ordered..Dammit
i believe spoolin up makes a plug in play bypass for the resistor box or you can backyard it by unmounting it, unplugging it cut the plug off of the resistor box leaving as much wire as possible coming out of the plug side and solder preferably but basically connect all 5 wires together. then plug the modified plug back into the vehicle harness. The resistor box basically takes one wire in (12v) and runs it to through a resistor then to each injector. you are effectively bypassing the resistors by cutting them out of the circuit and supply one side of the injector a true 12volts.
How to bypass the injector resistor box-
https://www.evolutionm.net/forums/ev...istor-box.html
Did it on mine. piece of cake!
FS[MidWest]: Fic 2150s
antilag_200
Nov 16, 2016 10:43 AM
WTB[MidWest]: WTB FIC 2150's
STLEVOIX
Aug 26, 2016 07:10 PM
WTB[MidWest]: FIC 2150's
2bar_evo
Jun 26, 2016 11:28 PM
