HELP!!! Best way to replace gasket on Exhaust manifold to downpipe
Old Mar 10, 2011 | 06:34 PM
Pallen2008's Avatar
Post Deleted
Old Mar 10, 2011 | 06:50 PM
heel2toe's Avatar
Take a look at this guide:
https://www.evolutionm.net/forums/ev...sing-pics.html
I do not know the specific name of the gasket but it goes between your o2 housing(megan racing piece) and your hotside (rusty cast iron piece)
Having done that install a couple of times I strongly recommend removing the radiator and splitting the hotside from the turbo to get it out
Old Mar 10, 2011 | 06:54 PM
Ginglingston11's Avatar
if you invest in the correct wrenches you wont have a problem with that last one and can be done without taking anything out. ill look for a pic of the wrenches im talkin bout
Old Mar 11, 2011 | 08:54 PM
tscompusa2's Avatar
o2 housing gasket = MR299686
o2 housing bolts MD062961 = uses 3 of these
o2 housing studs MR224441 = uses 2 of these
nut for studs MD050073 = uses 2 of these
washers for studs MD132933 = entire turbo area turbine housing area uses 9 of these but the o2 housing area only uses 5.
Old Mar 15, 2011 | 10:54 AM
809JDM's Avatar
Great info. Nice to know when Im doing my o2 housing swap
Old Mar 31, 2011 | 04:09 PM
Bashkimakasf's Avatar
Shouldnt be a problem if you have the right tools. Use a universal joint with the socket and you should be fine. Try to do it from underneath the car.
EvilDSM97
Oct 10, 2014 05:49 PM
essej
May 11, 2014 01:32 AM
hixlancer
Jul 23, 2011 04:11 AM
WarmPepsi
Feb 26, 2007 10:45 AM
1BlackEvo9
Dec 26, 2006 01:15 PM
