Painting Valve Cover Help
Old Jun 11, 2011 | 07:13 AM
polish_pounder's Avatar
Hey guys so i wanted to paint my valve cover this weekend and relocate my throttle cable at the same time but i have a few question.
- what is the best paint to use? i want a white cover
- what pattern are you supposed to torque the bolts down with
- what should they be torqued to?
- can you re use the gaskets?
Ill post more questions as i think of them thanks!
Old Jun 11, 2011 | 07:46 AM
Boltz.'s Avatar
FCOTM Winner
-Something hi-temp if you want white. Also use a clear coat. White paint + heat = yellow
-don't think it matters, just cross it around like wheels
-I never torque my valve cover to spec, just by hand
-Yes, if they are in good condition
Old Jun 11, 2011 | 08:11 AM
so with a clear coat it wont fade? and what kind of clear coat just the normal stuff from like pep boys.
and i donno valve cover bolts just scare me because they are supposed to be torqued to like inch pounds or some stupid **** so i never know how tight. just like hand tight? or barely even
Old Jun 11, 2011 | 09:54 AM
2005evo's Avatar
You ca use a simple duplicolor paint from your local hardware store. Its usually a 500F paint and it will be fine. I had a prelude and painting it with that and it lasted for 3 years without a problem and then i sold the car. Duplicolor also makes a clear 500F. The chips you see is me dropping my ratchet on it. That's why you need to clear it. Coat it once wait 15 min. Do a light coat. Then do a second coat wait for 15 min and then do a heavy 3rd coat and give it 48hrs. It takes paint 30 days to cure fully. If you dont clear you will learn like i did. And dont drop anything lol
Old Jun 11, 2011 | 10:26 AM
2005evo's Avatar
If you dont know much about painting you can relate it to my old thread when i had my first evo.
https://www.evolutionm.net/forums/ev...onditon-4.html
Old Jun 12, 2011 | 03:26 PM
ModifiedMR's Avatar
Personal experience rust-oleum is better than dupli-color. Just use high temp. I know dupli-color makes a high temp clear but i'm not a fan of their clears. I never did my evo valve cover but I did my Integra valve cover with high temp white and it stayed a nice bright white for a few years and was still that way when I sold it to pay for my evo.
Old Sep 9, 2011 | 05:50 PM
HateOnMyVIII's Avatar
I had a buddy of mine in NJ sand blast and powder coat my valve cover white for my 03 evo 8. It looks great, everything wipes right off. Depending on where you are located this kid might be able to help you out. I paid $70 for mine, If interested i'll talk to him for you.
Bright picture, but looks great IMO.
Old Sep 9, 2011 | 08:14 PM
BLK_EvIL's Avatar
just did mine wrinkle black wet sanded then layed it on i bought a gasket set from Kragen it was only 20bucks and came with spark plug hole gaskets and outer gasket and was oem quality torque inside out and its like 31in lbs aint much torque if you dont have a in lbs torque wrench go like 1/4 turn past finger tight
Old Sep 10, 2011 | 12:46 AM
hateonmyViii hit me up with a PM man thanks!
Old Sep 15, 2011 | 03:01 PM
YogSaahoth's Avatar
Veteran: Army
you get it done yet polishpounder? Don't forget to use gray rtv when u put the cover back on. You can re use the gaskets as long as they are in good shape.
http://www.evomoto.com/tech_articles..._article_id=18
^Cam install but it has good details about valve cover removal and re-install...
Old Oct 10, 2011 | 02:13 PM
drevoviii's Avatar
Definitely get a new valve cover gasket set. It seems like once you get the idea in your head to remove the valve cover, the gasket starts leaking. Follow the torque specs too as to not over tighten the bolts. They are something crazy low like 10 inch pounds or something like that.
Old Oct 10, 2011 | 09:13 PM
thanks alot man yeah it should get painted tomorrow i just been installing parts since sunday. doing my 60k kit cams, springs, retainers, headstuds & gasket, MBC. so should be fun to paint the Valve cover to hell were painting an eclipse white in the garage ahaha
Old Oct 11, 2011 | 01:18 PM
OreOs's Avatar
Don't forget to cover the head with somthin like a clean trash bag since you don't want any crap falling inside there while the cover is off.
supaduckie8113
Jun 20, 2013 05:01 AM
aggieEVO
Aug 13, 2012 09:53 AM
Tree
13
Jan 9, 2008 06:06 PM
