anyone have a link to rebuilding brembo brakes?
I looked in the stickies and through the threads but didn't really find anything good. If anyone has links or any type of DIY that would help please post it up on here.
thanks all!
thanks all!
here is a link to a decent step by step
http://forums.nasioc.com/forums/show....php?t=1600335
and girodisc.com has rebuild kits.
Whatever you do, Don't split the calipers. They are a PITA to get resealed since there's an o-ring in between the rear halves. Also, if you PC them make sure whoever does them doesn't coat over where the banjo bolt connects the brake line. It wont seal.
I just finished mine and I learned a lot and if you do replace the front dust boots and seals, order them from Subaru (part 26297FE010) they're less than half the price Mitsu or Girodisc will charge you and they're genuine brembo parts. The rears you might wanna get from Girodisc if you need them because the suby ones are smaller.
I too was told also NOT to split the calipers in half when rebuilding, but just to shoot it full of air and out pops the pistons. trying this tues or wed.
You are right do not seperate they are laser cut surfaces and you will not get them to seal again. Use air to get pistons out. and replace seals. Polish pistons real good and use lots of btrake fluid for reassembly.....Dont powder coat them cause it will ruin the seals on laser cut halves.
