1st mod for Stock Evo IX in NYC
I am planning to do my first mod on my stock Evo IX. I have been driving it for years but did not mod anything because of warranty. I am planning to install a HKS SSQV III Blow Off Valve w/ UICP . I will also install a Recirculation Kit for SSQV Kit with it.
Since this is the 1st mod for my Evo , I am wondering if BOV good for stock turbo as well as HKS turbo ? My plan is to install a turbo gaugenext then upgrade the turbo after BOV and turbo gauge (thinking of Defi-Link Meter ADVANCE BF Turbo Gauge with a Defi-Link ADVANCE SYSTEM ). The Reason for this is that I want to see how each mod will change my Evo's performance and the handling.
I think installing a BOV and turbo gauge is relatively easy to do and can be done in a locate shop. But upgrading turbo should require tuning the car ? I heard www.iveytune.com in NJ is pretty good. just not sure if I should have turbo upgrade in there or just locate shop is fine?
Any advise is welcome and appreciated!!
i wouldn't bother with the bov for now.
i would get intake, exhaust, boost controller,fuel pump,piping, front mount, and raise it up a bit.
stock dv is good up untill 26 psi. ive seen some guys run 30.
Please don't use the HKS BOV. For first mods start with a really good overhaul of basic maintenance. check your plugs, fuel filter, oils, battery, etc.. Then do the basic bolt ons next - exhaust, IC pipes. Then when you are ready for the bigger stuff go with injectors, fuel pump, a tune..
as stated above, the BOV doesn't need to be replaced for quite some time. But when you are ready, look at the Synapse. It's the last BOV you'll need to buy.
Maintenance - Agree with Wazzleby here and maybe check trans, tcase, diff fluids, and timing components depending on mileage on the car.
Mods:
BR, ETS, STM 3inch TBE
Vibrant Air Filter (Stock intake Snorkel works very well untill SD or a bigger turbo)
Walbro 255
Hallman MBC
Boost Gauge
Wideband Gauge (must have this for tuning)
TUNE (MOST Important Mod)
Idk what your budget is but thats about $2,000 in parts not including labor.
And take a look into DynoTech Tuning. Not to far from NY! And Jamie over there does a great Job with the stock ecu. Check out my signature if you want more info on them!
HTH
The idea of a BOV is to prevent pressurized air from going the opposite direction through the IC piping once you lift off and the throttle plate shuts. This causes compresssor surge, and can be harmful to a turbo at high levels of boost. But since the Evo (along with just about every other turbo car since...well for at least the last 30 years) comes with a factory fitted BOV, could you please explain how - at stock power levels - ANY type of aftermarket BOV be needed, or of any benefit whatsoever?
iLLevo_
16
Feb 19, 2017 09:30 AM
neojin24
Northeast Region
Nov 15, 2010 06:51 AM
InjectedPerformance
29
Sep 1, 2006 08:49 AM
RavSpec
28
May 11, 2004 11:36 PM
