knock sensor removal needed
Old Dec 29, 2011 | 04:42 PM
kimma's Avatar
please delete
please delete
Old Dec 30, 2011 | 06:21 AM
kimma's Avatar
really no one has messed with this
Old Dec 30, 2011 | 08:52 AM
Jonesey I7's Avatar
told you not to mess with that bro~~ It's the cams
Old Feb 1, 2012 | 03:54 PM
simons3z's Avatar
remove transfercase
Old Feb 2, 2012 | 06:37 AM
kimma's Avatar
got it taken care of thanks
Old Feb 19, 2012 | 09:36 AM
marcusE's Avatar
what did you do?
Old Feb 19, 2012 | 03:58 PM
eva2006's Avatar
I did mine this weekend, turned out my balance shaft was out of time and not a faulty knock sensor. But as for the knock sensor removal i had access to a lift so i removed the passenger front axle, (so i could access the plug) then came from the back over the transfer case with a 3ft-4ft extension with a swivel crows socket (homemade notch cut out) and got right on it. took about an hour. But id say to check you balance shaft first before removing and going through the head ache of the knock sensor.
Old Feb 20, 2012 | 04:09 PM
marcusE's Avatar
How do I check the balance shaft?
I'm getting 9 counts of knock under less then a psi of boost and the knock voltage is reading way low.. Gotta be the sensor?
Old Feb 26, 2012 | 08:12 AM
marcusE's Avatar
bump
