BR Double pumper help
Hey guys i was wondering if anyone had any advice and tips on installing the y lines and feeding them down and the fuel filter. And where the fuel filter is installed to. Is that going to the y lines. any pics would help. and yea i found the write up on highboost forum i just cant make out this part of the install very well. thanks for the help!
you feed the line around the tank, its a pain lol. the fuel filter just sits there, its a pretty tight fit to begin with.
the two lines that y out go to the double pumper and merges into the single line. that end goes to the fuel filter, then the other piece of small hose goes from the other end of the fuel filter to the stock line. you have to bend your stock line to get that hose to connect
one less headache to deal with now
Rather than start a new thread, thought I might ask a question about the same topic.
After installing the double pumper, are there any stock hard lines that need to be removed/plugged inside or under the vehicle? Whenever I fill up with E85 my entire garage and basement reek of gas. Is this the nature of the gas or am I missing a plug of some sort?
okevolutionVIII
Jul 23, 2012 07:34 PM
