High Pressure Fuel Pump Line MIA?
Old Dec 10, 2015 | 05:42 PM
RelentlessEVO's Avatar
Hey all,
So I'm putting this Evo IX SE back together (my thread can be found here: https://www.evolutionm.net/forums/pr...e-rebuild.html) and I went to install my fuel pump assembly, with my new fuel pump filter, and realized I was missing something important.
As you can see:
So, I looked between the floor pan and the top of the fuel tank and I do NOT see the missing line. The prior owner did have the EvoDan double-pumper fuel setup. I can only assume that it requires removal of that fuel line to work properly? Regardless, I don't have it. So I went under the car and checked out the lines going up to the tank and this is what I found:
Can someone tell me if I need to purchase the OEM high pressure fuel line or can I use regular fuel hose? Also, is the disconnected hard line underneath the car the same high pressure fuel line from the fuel pump assembly?
Any help would be greatly appreciated!
Thanks EvoM!
Old Dec 11, 2015 | 11:41 AM
Anyone able to provide some insight?
Old Dec 11, 2015 | 04:15 PM
Hotsauce101's Avatar
From the looks of it the owner probably had a new line put in? AN fitting for his double pumper? Why not just copy what he did?
Clipse3GT
44
Jan 29, 2022 09:54 PM
06EvoIXmr07
Jun 20, 2016 08:01 PM
Carloverx
14
Dec 22, 2011 01:00 PM
colo_evo
Dec 30, 2007 08:20 PM
GSknight
Dec 27, 2006 09:15 PM
