modded vs stock boost leak test help
Old Feb 14, 2012 | 09:27 PM
RenosEVO's Avatar
ok so ive done a lot of research for a boost leak test and i got all the neccesary tools. I tried it on sat and fail(i was pressuring air in the turbo and couldnt get no air to go in the tire valve thingy)
ive noticed it is a bit different when you have an intake because you just take off the intake and plug the tester on the turbo
Difference to me is on my stock the stock air filter is stuck with the stock bov and intercool tubing all in one. SO i disconnected the hose that goes to the turbo but doesnt that mean everything else is disconnected?? how can i test out the bov if it has a leak.
ill put some pics because this sounds confusing since i dont know much part names hope someone can help
Old Feb 14, 2012 | 09:29 PM
RenosEVO's Avatar
in this pic i see that all it takes is to unplug it and put the tester on, seems simple and the bov and other hoses are stuck to that intercooler piping thingy that goes to the throttle body
Old Feb 14, 2012 | 09:36 PM
RenosEVO's Avatar
this is how mine looks. notice that the bov is connected with the air filer, intercooling piping etc. will it be different to boost leak test??
Old Feb 14, 2012 | 10:50 PM
RenosEVO's Avatar
ttt anyone help with this crazy problem lol
Old Feb 15, 2012 | 07:47 AM
teribble's Avatar
you need to remove your intake and attach the tester to the turbo. disconnect the bov from the intake and leave it connected to the upper intercooler pipe to avoid a leak.
Old Feb 15, 2012 | 08:02 AM
mdsevo06's Avatar
This, and grab that breather tube from the Valve Cover that connects to your intake and pinch it while your pressurizing.
Old Feb 15, 2012 | 12:16 PM
teribble's Avatar
I don't like to plug the valve cover when testing. You can blow seals out by pressurizing the oil system/ motor.
Old Feb 16, 2012 | 08:33 AM
RenosEVO's Avatar
Oh ok so I just disconnect intake, and the bottom part of bov but leave it attached to to the intake piping and that's it??
Old Feb 16, 2012 | 08:35 AM
RenosEVO's Avatar
Do I have to cover the hole of the intake after removing it? Cus it'll just be dangling With a big open hole once removin from the turbo
Old Feb 17, 2012 | 09:27 AM
RenosEVO's Avatar
Ttt
Old Feb 19, 2012 | 03:17 AM
GG06MR's Avatar
No. You're removing the intake from the system, since it's not a concern during a boost leak test.
Old Feb 19, 2012 | 05:48 AM
Evoryder's Avatar
https://www.evolutionm.net/forums/8018340-post8.html
Old Feb 20, 2012 | 11:20 PM
RenosEVO's Avatar
oh ok so the air intake has nothiing to do with test right?
that doesnt make sense though because in the stock intake the bov is connected to everything as well so it is ok to just leave the intake hose stuck on to the turbo just loose and open? sorry if im sounding confusing
Old Feb 20, 2012 | 11:21 PM
RenosEVO's Avatar
removing the intake makes sense with the aftermarket one but the stock is connected with the intercooler piping and bov, where i might have a leak.
Old Feb 21, 2012 | 09:15 AM
GG06MR's Avatar
As long as you have a stable air supply, then the BOV should not vent/leak air until it reaches it's pressure capacity. If it does vent/leak, then you know that it needs fixed/replaced. It's all part of the boost leak test.
