How to Setup Tephramod V7
Old Mar 12, 2013 | 09:15 PM
detroit pistins's Avatar
Yes …more or less it’s the same. For instance, looking at ur fuel map (small vs big at loads between 320 and 350 @ 4k)
You can leave the 10.8 spread, however, if you decided someday to tune the 330 & 340 loads without impacting the 350 cell then you could do that with the bigger map.
Old Dec 4, 2013 | 08:53 AM
TCSTigersClaw's Avatar
Hello and thanks for the great tutorial !
Do I also have to copy paste all the Peripherals (or just leave them to 0 )
and also OBD 2 Codes ?
And one last thing. I am completely stock ,completely. Will removing the pill and adjusting
the WGDC do any good resutls ?
I think I can leave the fuel stock since its already to rich even if I increase boost no ?
Old Dec 4, 2013 | 10:06 AM
Raptord's Avatar
Regarding boost pill and WGDC, removing the pill will lower your boost, not increase it. Stock WGDC is already maxed out so that won't help you. You'd need a new boost pill with a smaller inner diameter or change the stock BCS for an aftermarket 3-port.
You'll need to check your wideband and see what adjustments need to be made to the fuel map.
Old Dec 5, 2013 | 02:10 AM
thank you ! I will report back
Old Dec 7, 2013 | 06:07 PM
Werdna06's Avatar
is there anything i should account for using a mbc?
Old Dec 7, 2013 | 08:21 PM
Raptord's Avatar
What do you mean?
Old Dec 9, 2013 | 03:28 PM
Werdna06's Avatar
is there anything i should take special attention on when not using ecu controlled boost? plus i was trying to use the map translator and i don't think the link is working. i was able to get it from google though.
Old Dec 9, 2013 | 03:39 PM
ReaperX's Avatar
Nope, you're good. Just set all the boost tables like you would in a standard rom for a mbc.
Old Dec 9, 2013 | 06:53 PM
Werdna06's Avatar
thanks again i'm sure you guys get tired of the newbie questions but i'm at a not starting repeated error from previous learners too. alright i see in the immobilizer hex part of the ecuflash it has different ones for different cars which one is for usdm 2006 evo IX? i did try searching but i just didn't understand the conversing between the troubled person and the solution giver lol.
0x0040 for 2003 or 0x0055 for 2004 or 0x0058 for 2005 USDM - 0x004D for EDM: ?
Old Dec 9, 2013 | 07:05 PM
Werdna06's Avatar
never mind found the hex, but just to make sure it is 0068 correct? well i just tried that and i'm still not starting...
Old Dec 9, 2013 | 07:46 PM
ReaperX's Avatar
Did you copy your immobilizer from your stock rom? The next box below that one must have the same value as your original rom. It will be labeled immobilizer under the ECU section of your original rom.
Old Dec 10, 2013 | 04:49 AM
Werdna06's Avatar
Yeah I copied it 0101. What other issue could it be?
Old Dec 13, 2013 | 11:03 AM
Werdna06's Avatar
I'd like to thank everybody that helped me with this difficult yet simple process lol. But i would like to point out ReaperX helped me immensely with figuring things out. Thanks everyone.
Old Dec 13, 2013 | 06:15 PM
ReaperX's Avatar
Glad I could help!
Old Feb 8, 2014 | 11:54 AM
tsitalon1's Avatar
Having a few problems logging boost error.
Using Tephra v7 in 88590715.
MUT 8A is set for 6ee3 and psi based boost control is working fine.
I'm trying to log boost error and I am getting "-3.087" accross the board.
Here is my evoscan entry:
Code:
<DataListItem DataLog="Y" Color="" Display="Boost Error" LogReference="BoostError" RequestID="8A" Eval="0.0241*x-3.087" Unit="psi" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-5" GaugeMax="5" ChartMin="-5" ChartMax="5" ScalingFactor="1" Notes="" Priority="1" Visible="false" />
Do I need to change anything to account for the Omni 4bar?
What else could be causing this logging issue?
