DIY Engine Dress-Up Bolt Kit on a Budget
http://www.boltdepot.com/Chrome_bolt...lugs.aspx?nv=l
Appreciate the write up Demon!
Would you or anyone know the battery tray bolt size? The heads got all rusted from battery acid and I was hoping to replace them with something that looks nice with my mini battery tray.
Pull one out and compare it to another bolt in the engine bay. If I had to make a random guess, I'd say it's (not M6 like my guess) M8
Is everyone here okay with the 25mm bolts for the valve cover? They do seem really long but I figured it's just in my head though I wanted to double check and make sure. They don't bottom out in the head correct?
No, they don't bottom out. I suppose I could measure the length of the bolts and adjust the bolts accordingly. I'll try and do that once I've moved into my new place and got unpacked
I didn't have a chance to look at my stock valve cover bolts, but Buschur sells a valve cover bolt kit and they use 25mm bolts in their kit. I'd say you're perfectly safe using 25mm length as opposed to 20mm or something like that
I never understand why people who don't have anything informational to give to a thread, post nonsense.
Or for that matter.. people who don't drive evo's post in here.. wtf over
Thanks DEMON and domyz... So it's likely a 8mm x 1.25mm bolt... Any chance you would know the length? I've been on a short term assignment in another state and can't check it on my car... I know the bolt can't be too long cause it will hit the frame... if anyone can confirm the two battery tray bolts for me I can do my boltdepot order before I get back home. Thanks.
Something to keep in mind is that BoltDepot doesn't have non-knurled 6x1x25mm bolts in stock. I call every week and ask!
I'd say 25mm would be a safe bet, may as well order a few lengths since they're so cheap though
Battery tray I can't help ya on!
