help with SD conversion
Old May 7, 2013 | 08:38 PM
Silver-IXse's Avatar
can anyone help me install the AIT sensor cause i was thinking of going speed density can you guys give me advise on the install thanks
Old May 7, 2013 | 08:48 PM
detroit pistins's Avatar
Do you have a particular reason why you want to install an AIT? few tuners around here are basing the calculation of ait based on fuel temp, so you may not need it unless your tuner requests it.
Edit: On a side note, if u decided to install one, u will need an ait sensor which most venders sell (i have new one for sale also ), weld a bung into ur ucip (thats how mine is setup), and a harness to connect the ait to ur maf adapter. http://www.spoolinup.com/ sells the harness if u dont wanna make ur own.
have someone else confirm this before ur make ur move!
gl!
Old May 7, 2013 | 08:59 PM
gl!
well i was told that you needed a ait sensor when you speed density as well with a omni 4bar ive notice websites that sell the package with ait and sensor and my uicp has a bung for the ait ...... thank you for the website btw help alot
Old May 7, 2013 | 10:16 PM
PureDrivePerformance's Avatar
You don't need it. I tune SD without it most of the time.
Jamie with DynoTech says to install it on the uicp right next to the intercooler to prevent heatsoak.
Old May 7, 2013 | 11:27 PM
Dynotech Tuning's Avatar
I generally recommend installing the G.M. IAT sensor as low on the UICP as possible to keep it out of the engine bay for minimal heatsoaking issues when the engine is hot and sits prior to returning shortly after. I also try to install the sensor on the top half radius of the pipe so any condensation or oil deposits cannot collect on the tip of the sensor. Basically the same principle used when installing a wideband O2 sensor on an exhaust pipe.
I'm a big fan of the GM IAT and not a fan of the fuel temp sensor. Why have somewhat accurate data when you can just have 'accurate' data?
-Jamie
Old May 8, 2013 | 07:52 AM
Thats very true jaime i was actually seeing people running it from the ecu fuel temp sensor and i notice it wasnt really accurate ..... On my uicp it actually has bung for the ait sensor which saves me the weld lol ..... Ive seen spoolin up offers a connecter that actually connects to the maf back to the ait sensor with out wiring or cutting things what do you think of that ....
Old May 8, 2013 | 07:53 AM
By the way what are the gains of going speed density ....hp or tq drive ability etc
Zin740
May 3, 2013 10:54 AM
faheemfb
Evo X How Tos / Installations
May 21, 2011 06:55 AM
guest49582
Mar 5, 2011 10:07 AM
Mishi9
Jun 12, 2010 11:06 PM
X1nicelancerX
Aug 15, 2005 03:03 PM
