DIY: a/c clutch
Old Aug 12, 2015 | 06:32 AM
cerevo's Avatar
It should be fairly uniform all the way around, it just needs to be close to pull the clutch together.
Old Aug 12, 2015 | 07:23 AM
nor11384's Avatar
FCOTM Winner
got it...thx...
Old Aug 14, 2015 | 08:32 AM
phrequenc's Avatar
thanks for responding and making this thread,
where did you order parts from?
is it nessecary to replace the other components? or is clutch coil suffcient? my car is very low mikeage and the parts are really clean
Old Aug 15, 2015 | 08:35 AM
cerevo's Avatar
Usually not necessary to replace everything. My car has 129k on it and it needed the coil and clutch but I just took the spacer off the clutch.
I also have been getting parts off amazon
Old Aug 20, 2015 | 06:46 PM
phrequenc's Avatar
i camt get the pully off for the life of me.
Old Aug 21, 2015 | 03:26 PM
cerevo's Avatar
I had to hit one side with a hammer and then hit the other side, after you take that spring clip out
That let me get it to where I could wiggle it off.
Old Aug 21, 2015 | 03:39 PM
phrequenc's Avatar
i took the c-clip out. and i hit it repeatably and i tried wigglying it from behind.
Old Aug 21, 2015 | 05:51 PM
phrequenc's Avatar
i was able to remove it with a pulley remover tool. forgot i had one -_-
that thing is wedged on there good.like a bearing almost.
and.......... it dont fix my problem. doesn't make sense.
Old Aug 24, 2015 | 01:42 PM
cerevo's Avatar
you're sure you're getting power to the wire going to the connector down there?
Old Aug 25, 2015 | 02:32 PM
phrequenc's Avatar
i tested it with a test light, its 100% getting power.
Old Aug 25, 2015 | 02:36 PM
cerevo's Avatar
remove all the spacers from the clutch, see if it engages then. I really should replace my clutch but it works without any spacers in it for the rest of this summer.
This winter I'll be getting a new clutch and pulley for it.
Old Oct 7, 2015 | 05:35 PM
Bally205's Avatar
Nice writeup
Old Oct 7, 2015 | 10:53 PM
EvoIX4Ray's Avatar
Very detailed write up!
Old Aug 2, 2023 | 02:55 PM
gbarnachea's Avatar
5 Year Member
I know this post is a decade old but THANK YOU! Had no AC for like 3 years cause I thought the compressor was done. Such a simple fix for a $30 kit
Old Sep 21, 2025 | 07:36 AM
november's Avatar
Originally Posted by gbarnachea;[url=tel:11971316
11971316[/url]]I know this post is a decade old but THANK YOU! Had no AC for like 3 years cause I thought the compressor was done. Such a simple fix for a $30 kit
i know it’s a long shot but which kit did you end up going with for $30?
