Clutch fell to the floor. What's broken?
Thats the 05-06 ACD line (ATF fluid), now you have to bleed it once you get it back together. You could've got the bolt out without removing the line if you have a wrench that fits between.
I highly recommend going to harbor freight and buy a trans jack if you don't have one.
http://www.harborfreight.com/450-lb-...ack-39178.html
So far I've got all the bolts holding the tranny off, I have a jack holding the tranny up at the seam and when I lower it, it gets snagged on the subframe. I'm contemplating buying one of those tranny jacks or renting an engine hoist. I'm at the end of my wits trying to get this damn thing out
So I got the tranny off and I've added pics of the TOB carnage, bearings straight up popped out and some even fused together
So I've got another question I was hoping to get some help with. At this point, how do I remove the leftover bit of the old TOB off the pressure plate?
Thanks for the all the input everyone, its greatly appreciated
Dude, I so feel your pain. Same thing happened to me at the track two weeks ago but I was at speed on track. Just ordered the engine support bar from Amazon today, and driving to Harbor Freight for the trans jack tomorrow. Ordered the ACT thing earlier in the week...
Good luck with the repair. And if you've got the cover off, might be time to do the clutch ''since you're in there". Also consider changing the rear main seal.
So, due to my ignorance I broke the (lever plate?) little ring with teeth crimped on the pressure plate. I can't seem to find that piece for sale separately, do I really need to buy a new pressure plate?
edit: damn ACT doesn't sell the retainer crown separately...gotta send in the pressure plate for a "rebuild" ....****
I replaced the TOB, pressure plate, and added an ACT monoloc instead of a wedge collar then got the tranny back on fine but I think I may have another problem. The TOB won't pop in when I try manually pulling the clutch fork towards the driver side.
Is there a certain way to get the TOB to pop into the monoloc?
