Battery trunk relocation
Old Jul 5, 2013 | 02:40 PM
mrm95's Avatar
So I want to relocate my battery to the trunk in my Evo 9. I was going to order a battery relocation kit off Summit Racing.
Link: http://www.summitracing.com/parts/sum-g1199/overview/
If you looked at the link I posted, is there anything else I will need? Such as fuses, etc?
I tried searching here on the forum but there was really nothing to answer my questions. Thanks
Old Jul 5, 2013 | 04:44 PM
nytalonTSi's Avatar
I relocated my battery a couple years ago. I would avoid the cheap plastic box.
I went with this kit, http://www.summitracing.com/parts/tay-48101/overview/
I didn't use anything else besides what came in kit. Unless you want to install a shut off switch, which I did not.
Old Jul 5, 2013 | 05:31 PM
mrm95's Avatar
Oh ok cool thanks. That Aluminum Box looks much better than the plastic box too.
Old Jul 7, 2013 | 02:50 AM
mrm95's Avatar
Oh and would anyone recommend only using a sealed battery in the trunk?
Old Jul 7, 2013 | 11:32 AM
AWDBus's Avatar
Most battery boxs are vented with a plastic tube. That second link has a vent tube, you just drill a hole out the bottom of the trunk and vent the gas out.
Old Jul 8, 2013 | 01:05 AM
mrm95's Avatar
Oh ok that makes this a lot easier. This method is cheaper than a small battery kit and more practical IMO.
Old Jul 8, 2013 | 09:35 PM
DropThatHammer's Avatar
I can make you a battery tray for around $50 shipped. But anyways, here is a link to a relocation write up.
http://forums.clubrsx.com/showthread...ery+relocation
It's on a DC5 Integra, but its very similar being that that car also uses a 12v battery.
Old Jul 10, 2013 | 02:17 PM
RESIDENT EVIL's Avatar
You can buy or make the tray cheaper than that plastic box. They typically fit full sized batteries , like optima red/ yellow tops. http://www.odysseybattery.com/battspecs.html. A925 mjt great sealed battery for the trunk with good reserve capacity and cranking power. And nice hold down http://www.odysseybatteries.com/accessories/welded.htm
Old Jul 17, 2013 | 11:32 AM
mrm95's Avatar
I will probably just get a box since they come with a ventilation tube.
Old Dec 25, 2013 | 02:03 PM
rick1024's Avatar
thats my boy zack
Old Dec 26, 2013 | 12:14 PM
neal.johnson's Avatar
it is alot cheaper if you make your own box.
Old Dec 27, 2013 | 07:05 AM
memphis69's Avatar
sorry
don't see any reasons for battery relocation to trunk
use http://shoraipower.com/lfx14a1-bs12-p62 in your engine bay and forged about relocation
it's cheap, lightweight and simple
Old Dec 30, 2013 | 12:54 PM
EvokidIX's Avatar
I didn't like the idea of running an aluminum box so I used this one
Moroso battery box
http://www.summitracing.com/parts/mor-74051/overview/
Very clean instalation
Old Dec 31, 2013 | 12:32 AM
xXANCHORMONXx's Avatar
Moroso battery box
I have the same one.
I liked the plastic box over metal as well.
Your going to need
-6- 0 gauge copper terminals
-Thick shrink tubing, Home Depot has this about 3/4 inch inner diameter
-inline fuse holder and 200 amp fuse
-2 0 gauge oem style terminals (solder style)
- 20 feet of 0 gauge wiring
-summit racing plastic battery box, just the box that's it.
-odyssey pc925 get the basic one
I soldered the connections as well.
I used 0gauge 10feer there and back.
I used the oem transmission ground and used a secondary ground on the rear strut tower.
Hope this helps
Pm me for more info
Old Dec 31, 2013 | 01:03 AM
jason42003's Avatar
For a cleaner look up in the engine bay area you can also use the distribution block cover and mount for an evo x. There are a few guys on here that are running that set up and it provides all the protection and a nice clean install look.
