Evo 8 oem hid headlight to halogen headlight ???
Old Nov 8, 2013 | 10:07 AM
Pawl7's Avatar
Question Evo 8 oem hid headlight to halogen headlight ???
Ok. So I found some posts on how to convert there non HID Headlights to HID's..
But mine is the other way around...
I have a evo 8 with factory hid. I was involved in an accident and my front was messed up. I am very low on funds so I just bought a OEM non HID headlight from a fellow member.. Now the problem is the wiring is different.
On the good side. I still have the broken headlights and pretty much the Projector lens, fogs, ballast and wiring's are all good.
Now my question is..
Is it possible to transfer all the OEM HID stuff to a NON HID Headlight?
I know the part on the bottom of the headlight where the wiring of the ballast goes to needs to be cut out and the fogs as well..
But Before I go through and remove the headlight lens, I would like to confirm first if anyone here knows if its possible, and if anyone ever done it.
Old Nov 8, 2013 | 02:37 PM
deylag's Avatar
They are different but the same. Obviously, that's confusing but it describes how the headlights casings are produced. Mitsu made the headlight casing for the non-HID headlight a modified version of the HID headlight casing.
I have both types of headlights. The modifications to install the HID projector can be done but the foglight and other parts needed will be hard to install unless one has experience with this type of work.
Old Nov 8, 2013 | 03:40 PM
Pawl7's Avatar
hmmm. so if the projector hid's are possible, then that's enough for me to go forward.
thanks deylag!
Old Nov 18, 2013 | 08:51 PM
Ian0611's Avatar
I have a similar question. Is it possible to install non-HID headlights on a car that has HIDs and just run them as regular headlights or is the wiring all different??
Old Nov 19, 2013 | 09:45 AM
Pawl7's Avatar
This is what I am trying to do first. But no... The socket from the car and the headlights are different..
it is possible.. you just have to bypass the connector and tap on the harness...
I really don't want to tamper with my wiring so I transferred all the parts from my HID to my NON HID.
The Projector and even the Fog light works. although the Motor is not possible to adapt.
Old Nov 19, 2013 | 10:02 AM
Ian0611's Avatar
Thanks for the response. I guess I need to find HIDs then since I don't want mess with hacking up the wiring.
Old Nov 19, 2013 | 03:50 PM
EvokidIX's Avatar
There has to be a way to install GSR headlights on your car with a aftermarket HID kit. For example, on my GSR I had an aftermarket HID kit already and I installed factory HID headlights (without the OEM ballast) on my car and all I had to do was buy D2S bulbs that would plug into my aftermarket HID kit to make it work. So I wonder if you could just buy an aftermarket D2S hid kit and use 9006 hid bulbs instead of the d2s's?
SnailSpeed
Jan 27, 2017 07:47 PM
BlueEvoEx
Feb 2, 2015 06:48 PM
06rallyred
Dec 15, 2014 08:42 AM
ekinshuya
Aug 7, 2014 04:48 PM
REV.olution
Feb 25, 2010 06:50 PM
