Aerocatch hood latches
Old Mar 12, 2014 | 07:21 AM
Ckeesee12's Avatar
I just got in my Aerocatch hood latches. I went with the top mounted, plus flush ones with locks.
I've seen plenty of write ups on how to install them and to measure one million times. My question is, what should I use to cut through the carbon fiber/fiber glass body of the hood. I was thinking of using a dremel with a diamond cutting wheel on it.
Any ideas?
Old Mar 12, 2014 | 07:30 AM
Ev0ikon's Avatar
This. And keep it at high speed.
Old Mar 12, 2014 | 09:09 AM
Ckeesee12's Avatar
Thank you good Sir!
Old Mar 12, 2014 | 11:15 AM
Tevenor's Avatar
Taping off the area on the top side will help keep burring and splintering to a minimum.
Old Apr 21, 2014 | 06:06 AM
Kevin Troy's Avatar
Here is How I did mine 2 days ago;
Old Apr 21, 2014 | 06:23 AM
NJ9MR's Avatar
FCOTM Winner
Nice work! Thank you for this thread! Really helpful!
Old Apr 21, 2014 | 06:53 PM
truthdweller's Avatar
Veteran: Navy
Curious, what was the loctite for, to fill gaps? I ask, for I just did mine as well...
Edit: sorry about posting non-evo photos.
Old Apr 21, 2014 | 07:02 PM
deylag's Avatar
Its to make sure that the screws and mounting plate don't loosen themselves over time.
Old Apr 21, 2014 | 07:13 PM
Veteran: Navy
Im reffering to the loctite on the bottom surface of the top latch flange. The hex-nuts are lock nuts themselves and are seated inside hex holes on the bottom flange. To prevent loosening of the nuts and/or bolts the benefit would be to apply loctite to the nuts and/or bottom surface of the countersunk bolt heads.
What was your intention Kevin Troy?
Old Apr 21, 2014 | 07:18 PM
Veteran: Navy
The instructions say to use silicone to fill gaps when mounting over radii, and this is what appears Kevin used Loctite for, I could be wrong.
Old Apr 22, 2014 | 12:19 AM
Kevin Troy's Avatar
I actually put the rtv (Loctite) to fill in the gaps and to prevent water and humidity while washing the car of getting in between the layers.
thanks to all your comments
Old Apr 25, 2014 | 09:10 PM
DRO.Evo8's Avatar
Not a big fan of hood latches but these look ok
Old May 3, 2014 | 11:05 PM
GSXPimp's Avatar
These look sick I want some now
Old May 6, 2014 | 01:36 PM
Veteran: Navy
My Duraflex Evo 5 hood with Aerocatch latches and recessed Naca vents...
Old May 11, 2014 | 06:43 PM
xXANCHORMONXx's Avatar
What do those vents cool?
