Insturctions for OEM Window Vent Shades
Hi guys,
Does anybody have a write-up or a copy of the instructions from Mitsubishi for the side window vent shades? I misplaced the original instructions that came with my set. Any help would be appreciated. Thanks guys !
Fred
Fred
The original instructions sucks and don't really tell you anything. It's not that hard.
pull down the weather stripping from the top of the window
push the clips in
Line it up and use the provided double sided tape
push the clips in
It's super easy man. Like said earlier, remove window seal at top of windows in the channel, pop in your clips. Clean the top of the door frame (mating surface for tape) and line them up and while they are clipped in, peel your tape. Press down as you go. Just make sure they are lined up good. Literally took me like 30 mind to do all 4.
wallie123
Jun 29, 2016 03:27 PM
R. Burgundy
Aug 15, 2012 09:35 PM
