Autometer oil pressure gauge issue?
Old Dec 4, 2016 | 07:33 PM
superkizuna's Avatar
Forum,
Just intalled a new autometer oil pressure gauge. Using an 'add a fuse' to tap the gauges fuse, grounded to chasis. Turn car on and gauge sweeps and then pegs at 100 and stays. Is the sender faulty? I am runnin a 3a fuse on the tap along with thr 7.5a for the gauges.
Old Dec 5, 2016 | 08:33 AM
So then the gauge started working after I re-did the wiring. I'm guessing that Evo IX idles at around 20psi when warm?
Old Dec 5, 2016 | 09:36 AM
Ev0ikon's Avatar
That's good pressure for stock cams!
Old Dec 5, 2016 | 03:39 PM
4b11slayer's Avatar
Is it digital Guage? If so is there any scaling settings? I.e psi,bar or kph
Old Dec 7, 2016 | 04:56 PM
I have 264/264 cams. that still good?
Old Dec 7, 2016 | 04:57 PM
No, the face is analog but the gauge is electric. Its graduations are psi.
Old Dec 14, 2016 | 11:13 AM
Ev0ikon's Avatar
Those are relatively mild cams so they will keep the pressure around stock level too.
Old Dec 14, 2016 | 12:26 PM
kaj's Avatar
kaj
I'm 20-25psi depending on oil. You're good.
Old Dec 14, 2016 | 04:55 PM
lonestarr20's Avatar
Where did you install the sender head, ofh????
Old Dec 15, 2016 | 06:21 AM
Tapped by the filter. Also, does filter choice affect readings with any real difference?
Old Jan 8, 2017 | 08:53 AM
Martymo's Avatar
I am pretty sure that i´ve read that different oil filters can affect the oil pressure a little, i have always been running the same ones tho, so i can´t confirm anything.
Old Jan 8, 2017 | 11:25 AM
If you tap the oil filter housing for pressure reading, cold starts for me I was well past 100 psi, using 20/50w at the time.
So if you tapped the housing, you will need a gauge to read 150 psi so you don't damage your gauge
Old Jan 9, 2017 | 05:58 AM
I have an electrical gauge, does that matter in the 'breaking' situation?
Old Jan 9, 2017 | 06:32 PM
If it's digital and pressure exceeds the rated psi it's capable of reading, it should just go blank.
Once the car comes up to temp, the pressure will decrease, and the gauge will work correctly.
GotWheelHop
Mar 5, 2014 01:56 AM
EVOVIIImadrid
May 21, 2013 07:13 AM
sekula
13
Aug 4, 2009 09:43 PM
sekula
Jun 1, 2009 09:33 AM
