Evo 8/9 cluster pin out
Old Jan 11, 2019 | 10:18 AM
sleepy_evo's Avatar
hello im currently in the process of having a LED cluster made for my Evo 8. but i can not find a schematic any where that has what each pin for the cluster does and the specific parameters for them. was wondering if anyone had any info on this?
Old Jan 11, 2019 | 09:04 PM
Teal2nnr's Avatar
C-106 (White Connector)
1 BLK...........Ground 3
2 BLK...........Ground 3
3 BLU/GRN.......Left Turn Signal (+)
4 RED/WHT.......High Beam (+)
5 BLK...........High Beam (-)
7 RED/BLK.......J/C 1 (+) (10AMP FUSED)
8 YEL...........Door (+)
Ignition
9 YEL/RED.......Charge (+)
10 GRN/WHT......Tarmac (-)
11 GRN..........ECU/Tach Input
12 WHT/BLK......Speedometer Input
13 GRN/ORG......ABS
14 PNK..........Gravel (-)
15 VLT..........Snow (-)
16
17 WHT/BLU......Check Engine (-)
18 WHT..........Oil (-)
19 RED..........Charge (-)
20 BLU..........Fog (+)
21
C-108 (Blue Connector)
31
32 BRN..........Brake (-)
33 VLT..........Water Spray (-)
34 BLU..........Door (-)
35 RED..........Seat Belt (-)
36 GRN/YEL......Air Bag (-)
37 BLU/GRN......Brake (+)
Positive Lead
38 GRY..........General (+)
39
Negative Lead/Rheostat
40 BLK/YEL......J/C 3 (-)
41
42
43
44
45
46
47
48 BLK..........(-)
Fog (-)
Turn Signal (-)
49 PNK..........Right Turn Signal (+)
50 YEL..........Water Temp Input
51 GRN..........Fuel Gauge Input
Fog Light Switch
3 - Black Yellow - From Rheostat
4 - Green White + From fuse box 7.5a
Hazard Warning Light Switch
3 - Green White + From fuse box 7.5a
4 - Black Yellow - From Rheostat
Old Jan 12, 2019 | 09:42 AM
sleepy_evo's Avatar
What are the voltages for all the pins and are they all the same across the board?
Old Jan 12, 2019 | 02:31 PM
Teal2nnr's Avatar
That I can't tell you. I'm assuming 12V across the board. Just measure the connector with a volt meter, wouldn't take long at all. The cluster comes out in 3min.
