Make you front sway bar adjustable.
Old Apr 3, 2004 | 06:03 PM
Tri-Bar's Avatar
Jack up the car and remove the wheels, place jack stands under the lower control arms.
Remove the tie rod end from the spindle. Undo the end links. Using a 27/34”drill bit I drilled center-to-center ¾”. The sway bar mounting tabs are an inch thick. You will need to mark ½” down to center. Place a two by four under the sway bar. Drill…drill and drill. This may take some time. The sway bar is made out of hard spring steel. When the hole is done you can put it all together.
http://www.we-todd-did-racing.com/we...MXk1NDE%3D.jpg
Old Apr 12, 2004 | 09:34 PM
LancerEvoMR's Avatar
Discuss thread here
