In Stock Electronic Blowout- Turbo Timers From $50-Defi Triple Gauge Packages $699
All Items in stock ready to ship. Guaranteed the best price anywhere...
If you find them somewhere else we will beat their price.
HKS Turbo Timers
Old Version
Type 1 Limited
$75 Shipped
Type 1 Silver
$75 Shipped
HKS New Style TurboTimers
Free Timer Harness
Type 0
$99 Shipped
***Free Peak Performance Turbo Timer Harness EVO 8-9 Only***
Type 1 Silver
$145 Shipped
Twin Power DLI II
Display Model
The Twin Power ignition amplifier incorporates both the CDI and transistor method ignition to provide optimum spark duration and maximum voltage output, resulting in crisper throttle response and a smoother engine powerband. The CDI method, capacity discharge ignition, provides maximum voltage by transferring all stored energy in the capacitor to the ignition coil so that the ignition current can buildup quickly, thus making the Twin Power very effective in the higher revs where a normal spark would tend to diminish. This strong rapid spark prevents the high rpm ignition miss that reduces peak power. The transistorized method generates high voltage by using transistors to cut off current to the coil, thus allowing for a long energy discharge. This longer spark duration allows the Twin Power to improve lower RPM throttle response and torque. The combination of the CDI and the transistor method incorporates two distinct systems into one high performance unit, hence the designation of Twin Power. The Twin Power produces a spark output that is typically 1.5-2.5 stronger than of the stock ignition system and consumes about 35% less power input than other ignition amplifiers. Each compact and attractive Twin power unit is constructed of durable anodized aluminum and sealed to prevent corrosion from moisture. General wiring harnesses are included in each unit to aid in installation and mounting. Vehicle Specific wiring harnesses are also available for certain models to further aid in installations that require intricate integration.(CARB E.O. # D-186-22)
$425 Shipped
***Open Box Display Item-Brand New Never Been Used***
[FONT='Calibri','sans-serif']***HKS Twin Power ignition amplifiers have been designed to work with vehicles utilizing the OEM ignition system, fuel management, Engine Control Module (ECM) or Electronic Control Unit (ECU) and with vehicles equipped with the HKS F-Con Engine Management system. HKS cannot guarantee compatibility with other aftermarket manufacturer's products.***[/font]
Greddy Full Auto Timers
Free Timer Harness
Black & Silver
$99 Shipped
Greddy Profec B Boost Controller
Silver & Black In Stock
$349 Shipped
Apexi Timers
Free Timer Harness
$99 Shipped
Apexi Rev Speed Meter
Silver
$199 Shipped
Blitz FATT DCIV
Black
$99 Shipped
Blitz Dual SBC R Boost Controller
$399 Shipped
Blitz SPC ID Spec R Boost Controller
$499 Shipped
Blitz Power Meter ID
D1 Spec Limited Edition
$225 Shipped
D1 Spec Auto Timer
$69 Shipped
STRI Turbo Timer
$75 Shipped
Okada Projects Plasma Direct
The Plasma Direct is the ignition coil with a high power amplifier built in to it. The Plasma Directs produce 4 times more spark energy than stock coils and also generate an ultra fast multi spark discharge of 10 sparks up to highest RPM.
The spark amperage is increased 100%, allowing the spark to reach many more molecules and therefore accelerate the ignition and combustion process. This is extremely important in forced induction applications but also improves the performance of normally aspirated engines.
The Plasma Direct will increase horsepower and torque throughout the entire rpm range. This upgrade will also reduce fuel consumption. Even the engines with a legendary smoothness will be further refined with the Plasma Direct upgrade. Our Plasma Directs are OBD II compliant and C.A.R.B. approved.
Installation is easy. Direct bolt-in to the engine, no splicing or cutting into stock wiring, simply replace the stock coils with our Plasma Direct Coils and ready to go!
-100% secondary current (Spark Amperage) increase
-4 Times Spark Energy Increase for the initial spark discharge
-Easy installation. Only replace stock coils to Plasma Direct
-Compatible with all OEM components
-Compatible with OBD-II (On-Board-Diagnostics)
PM For Super Cheap Price
Gruppe-S Gauge Panel
Exclusive to Gruppe-S, we have developed an extremely high quality gauge panel for the EVO 8. This gauge panel is made from high quality ABS plastic. Fitment is excellent and it retains factory clips. Supports 60mm gauges (We recommend DEFI or Omori gauges - Some gauges may require modification to the radio bracket). Retains the factory look by using the OEM climate control stickers (not included, can use your existing ones, or purchase new ones from dealer for under $25). The gauges are oriented toward the driver for comfortable viewing (LHD only). Direct bolt on for USDM Evo 8. No drilling required.
52mm Gauge Fitment
$89 Shipped
60mm Gauge Fitment
$89 Shipped
Defi Gauges
The BF Series has a unique "masked" look that hides the gauge face until the car is started. Then you are treated with startup and shutdown sequences. These gauges are manufactured using the special manufacturing process used to by Defi's parent company to make many OEM gauge clusters such as for the STI.
Defi BF Package 60mm(Black/White)
-Defi V2 Control Unit
-Boost + EGT + WT or OT
-Gruppe-S Triple Gauge Pod
$949 Shipped
Defi BF-R Package 60mm(Black/Red)
$949 Shipped
Blitz MD (Mirror Drive)
Identified by its "Mirror Face", the MD (Mirror Drive) Racing Meter features a carbon or white face and brushed aluminum bezel. The face of the gauge is back-lit with LED light bulbs and the needle is lit red. When the gague is off, the face disappears and your reflection can be seen, hence the name Mirror Drive. The MD Racing Meters are full electric gauges and are available in boost, oil/water temperature, oil/water pressure, and exhaust temperature. (Available only in 60mm, all gauges include necessary hardware and sensors.)
Blitz MD Gauge Package 60mm (Black/Red)
-Blitz MD Electronic Boost
-Blitz MD Electronic Water Temp
-Blitz MD Electronic Oil Temp
$599 Free Shipping
AIM Sports XML Gauge Cluster
-1 AMP + 2 binder connectors
-Lap Times & Split Lap Times
-RPM - numerical and graphical display tach
-Max RPM stored for later recall
-Total Run Time
-Gear Position
-Total and partial odometer
-8 analog sensor inputs for temperature, pressure, lambda sond, potentiometers, etc.
-1 wheel speed input.
-128 kb of non-volatile memory.
-Brilliant blue display with backlight.
-6 fully configurable alarm LEDs.
-10 fully configurable shift LEDs.
-Requires 8-15V power from vehicle. Auto Power OFF feature.
-Weight: 21.2 oz (600 grams)
-Size: 6.9"x4.3"x1"
$1099 Shipped
HKS Turbo Timers
Old Version
Type 1 Limited
$75 Shipped
Type 1 Silver
$75 Shipped
Free Timer Harness
Type 0
$99 Shipped
Type 1 Silver
$145 Shipped
Twin Power DLI II
Display Model
$425 Shipped
Free Timer Harness
Black & Silver
$99 Shipped
$349 Shipped
Apexi Timers
Free Timer Harness
$99 Shipped
Silver
$199 Shipped
Blitz FATT DCIV
Black
$99 Shipped
$399 Shipped
$499 Shipped
$225 Shipped
D1 Spec Auto Timer
$69 Shipped
STRI Turbo Timer
$75 Shipped
52mm Gauge Fitment
$89 Shipped
60mm Gauge Fitment
$89 Shipped
Defi Gauges
$949 Shipped
$949 Shipped
$599 Free Shipping
-Total Run Time
-Gear Position
-Size: 6.9"x4.3"x1"
$1099 Shipped
Countdown to Xmas Sale...
From now on untill X-Mas. Gruppe-S will be offering a new daily special each day. This will be a 1 day sale. Everyday the sale item changes. Remember 1 day sale only for each item. Dont miss out.
Countown To Christmas Sale
