STRI Racing Gauges, Turbo Timers and Accessories
Old Jan 28, 2009 | 11:41 AM
RavSpec's Avatar
Exclamation STRI Racing Gauges, Turbo Timers and Accessories
ALL STRI Gauges are display in PSI or Fahrenheit Unit
Available in two different series. DSD series (stepping motor + user preset warning) and X Line series which are non-stepping motor and factory preset warning, thus half the price of the DSD series.
STRI's top of the line gauges with their many impressive functions & features make them a choice by many top professional racers and tuning shops. The X-Line is one of the latest models released by STRI. By using an advanced microprocessor the X-Line gauges are highly responsive, reliable and precise. X-Line gauges are available in two sizes 52mm and 60mm and your choice of either a black or white face with amber or white illumination.
Official Website: http://www.striracing-usa.com/hom.htm
DSD Series - Stepping Motor + Electronic Warning Gauge + Smoke Lens
DSD warning gauges offer all of the functions a demanding driver requires. Driven by rugged stepper motor, the DSD gauges inform you of your car’s vitals with extreme accuracy. Controlled by an advanced microprocessor, the DSD gauges are the latest in technology. Using the highest quality components DSD gauges will keep tabs on your car with surgical precision. . The DSD warning gauges are available in two sizes, 52mm and 60mm.
They are available in two models, the CS or the SLM series.
DSD Line FUNCTION
- User Preset Warning
- Peak Recall
- Auto Self Calibration
- 270 Degree Sweep
- Short circuit auto detect
- Sequential open / closing mode
- Dimmer function
- High brightness LED
- Light weight aluminum casing.
- All sensors included
- Mounting solution included
- Available in smoke lens - black or white LED backlight
- Available in white face - green LED back light
- Available in black face - amber LED back light
- Available in 52mm or 60mm size
Boost (30 PSI ) - $139.00 (electronic gauge)
PSI Unit
Boost (45 PSI) - $159.00 (electronic gauge)
PSI Unit
EGT - $145.00 (electronic gauge)
Fahrenheit Unit
Oil Pressure - $169.00 (electronic gauge)
PSI Unit
Oil Temp - $109.00 (electronic gauge)
Fahrenheit Unit
Fuel Pressure - $169.00 (electronic gauge)
PSI Unit
Water Temp - $109.00 (electronic gauge)
Fahrenheit Unit
Tach - $99.00 (electronic gauge)
Voltmeter - $99.00 (electronic gauge)
X Line Series FUNCTION
- Factory Preset Warning
- 270 Degree Sweep
- Start up open mode
- Dimmer function
- Available in black face, white face or smoke lens
- Available in white or amber LED backlight
Boost - $59.00 (mechanical gauge)
PSI Unit
EGT - $109.00 (electronic gauge)
Fahrenheit Unit
Oil Pressure - $79.00 (electronic gauge)
PSI Unit
Oil Temp - $69.00 (electronic gauge)
Fahrenheit Unit
Fuel Pressure - $59.00 (electronic gauge)
PSI Unit
Water Temp - $69.00 (electronic gauge)
Fahrenheit Unit
Tach - $59.00 (electronic gauge)
Voltmeter - $59.00 (electronic gauge)
Vacuum - $59.00 (mechanical gauge)
PSI Unit
Gauge Accessories
- Oil Block Adaptor Kit - $39
- Water Temp Adaptor Kit - $25
- Fuel Sensor Adaptor - $25
STRI Racing Turbo Timer + EVO VIII/IX Harness Kit
$70 shipped
Color: Black or Gun Metal (silver) Available
Function: Volt Reading, A/F Ratio Reading, Manual Timer
Harness: EVO VIII/IX Harness Kit Included
Old Jan 30, 2009 | 01:28 PM
RavSpec's Avatar
Weekend Bump!
Old Feb 3, 2009 | 07:18 PM
6-speed's Avatar
Quick?
Where is the button or buttons to set the preset warning or peak recall on the DSD gauges?
Thank you.
Old Feb 4, 2009 | 09:33 AM
RavSpec's Avatar
Originally Posted by 6-speed
Quick?
Thank you.
They are not on the gauge itself, to be mounted up to 40" away from the gauge.
Thank you.
Old Mar 27, 2009 | 02:02 PM
RavSpec's Avatar
Weekend Bump.
Old Mar 31, 2009 | 02:16 PM
Gamble's Avatar
Quick?
Thank you.
Or you can use the button on the back of the gauge.
So far I have Stri dsd slm II gauges:
boost
oil pressure
water temp
turbo timer.
Old Apr 1, 2009 | 11:17 AM
RavSpec's Avatar
boost
oil pressure
water temp
turbo timer.
Yes, Thank you.
The DSD's now come with individual mounting cups, so the buttons on the back of the gauge will be covered.
Old Apr 1, 2009 | 07:45 PM
Gamble's Avatar
WTF, do all the gauges come with mounting cups? When I got all my gauges only 1 did, and I talked to Stri and they said they are just including it in some of the gauges.
Old Apr 2, 2009 | 07:54 AM
RavSpec's Avatar
Did you buy them from us?
Old Apr 2, 2009 | 08:30 AM
Gamble's Avatar
Nope, but the next one I will. Next one I'll buy is a fuel pressure gauge.
Old Apr 2, 2009 | 10:32 AM
RavSpec's Avatar
Oh, OK... I'll make sure to include the cup, + we sell then as well.
Thank you.
Old Apr 2, 2009 | 01:55 PM
frost318's Avatar
how much for 60mm boost 45psi, egt, oil pressure in black face amber led? shipped to 70592
Old Apr 2, 2009 | 02:12 PM
RavSpec's Avatar
Prices listed + $12 for shipping, but we have to special order the 45psi boost.
Thank you.
Old Apr 2, 2009 | 08:29 PM
Gamble's Avatar
Thank you.
$12 for the gauge? That has to be a type o.
Also do you have any pics of the Oil Block Adaptor Kit - $39 ?
Old Apr 3, 2009 | 02:54 PM
RavSpec's Avatar
$12 for shipping.
