Haltech | AEM | Sun Auto | HKS | Blitz | GReddy | Innovate | more
Electronics for your ride. Everything from Widebands to PnP ECU's. Send me a PM, email chris@injectedperformance.com, or post on here and I will send you a quote.
Haltech High Performance Fuel and Ignition ECU's
Platinum Sport 1000 PnP(for EVO1-8)
With 8 channels capable of controlling injection and ignition duites, the Platinum Sport 1000 can support most modern engines (including 2 rotor engines) with multi-coil or conventional distributor ignition systems as well as aftermarket CDI systems.
It is capable of controlling sequential injection on engines up to 4 cylinders, or semi-sequential up to 8 cylinders, combined with direct fire ignition for engines up to 4 cylinders or wasted spark ignition on engines up to 8 cylinders.
Features:
- 8 additional user-definable auxillary inputs
- Up to 9 additional user-definable auxillary outputs (Depending on configuration)
Features:
Platinum Sport 2000 PnP(for Evo9 w/MIVEC or EVO8 w/ water spray output)
With 14 channels capable of controlling injection and ignition duites, the Platinum Sport 2000 can support most modern engines (including 3 rotor engines) with multi-coil or conventional distributor ignition systems as well as aftermarket CDI systems.
It is capable of controlling sequential injection on 4,6,8,10 & 12 cylinder engines and direct fire ignition for engines up to 6 cylinders, or wasted spark ignition on engines up to 12 cylinders.
Features:
- 11 additional user-definable auxillary inputs
- Up to 13 additional user-definable auxillary outputs (Depending on configuration)
Features:
Innovate Widebands
HKS Electronics
Boost Controllers, Turbo Timers, Twin Power
GReddy
Turbo Timers, Boost Controllers, E-Manage
Sun Auto
Ignition Strengthening and Tuning System, Grounding System, Voltage Stabilizing System
Absorbs all back electromovtive force, which aids to improve plug voltage and promote complete combustion by producting 100$ coil efficiency. Also, the hyper Force System eliminates any ignition performance loss due to descreased electrical current under heavy throttle. Since ignition efficiency over the entire revolution range improves, available torque and acceleration response improves; this efficiency enhancement also contributes to better fuel efficiency and a reduction of harmful emission.
Custom-tailored for the best fit and best performance in your vehicle. Giving your car a more efficient ground will help to pull out its full performance potential. The cables used are unlike anything else available: thick-gauge, 99.99% pure copper with 1477 strands per cable, 4-layered shielding, and gold-plated terminals.
Designed to stabilize voltage in your vehicle for maximum battery efficiency, allowing its full potential to be released.
Blitz
Turbo Timers, Boost Controllers, Throttle Controller
AEM
Widebands, ECUs, Fuel/Ignition Controller
Apexi
Power FC, Turbo Timer, Ground Stabilizer
